Horizontal spring with friction
The discussion revolves around calculating the coefficient of kinetic friction for a mass released from a compressed spring. The spring has a constant of 105 N/m and is compressed by 0.1 m with a 2 kg mass. The work done by the spring is calculated using the formula for spring potential energy, and the energy lost to friction is equated to this work. The key equation derived is 0.5*k*x0^2 = C * mg * distance, where x0 is the initial compression and distance is the movement after release. The conversation emphasizes using conservation of energy to solve the problem effectively.
Ali 2
A spring with negligible mass has a constant of 105 N/m. It has been compressed horizantally with a 2 kg mass for a distance of 0.1m. If the mass has moved after release for a distance of 0.25m, what is the coefficient of kinetic friction between mass and horizontal surface.
F=-kx (spring force)
f= C N, f is friction, C is the kinetic friction coefficient, and N is the force exerted on the mass by the horizontal surface
i would recommend using work to solve this problem.
Work=force*distance
also work done by a spring is .5*k*x^2
Conservation of energy would be the easiest way to solve this.
What happens to the potential energy initially stored in the spring?
hello
ok the work done by the spring is 0.5*k*x02 - 0.5*k*x12
we know that x0=-0.1m
but what is x1, since the 0.25m given in the question is the distance not the displacement??!?
ok i see what you mean ap123
the energy stored initially = the work done by the friction force
0.5*k*x0^2= C * mg * distance
Yes, you've got it :)
