Horizontal Tension Between Two Blocks?
The problem involves two blocks connected by a rope being pulled by a horizontal force. The context includes concepts from dynamics, specifically relating to tension, friction, and acceleration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to determine the tension in the rope by considering the net force and frictional forces acting on the blocks. Some participants question how the mass and friction affect the acceleration and tension. Others suggest focusing on the net force acting on the system.
Participants have engaged in exploring the relationship between the applied force, mass, and friction. Some guidance has been offered regarding the acceleration of the blocks and its impact on tension, though there is no explicit consensus on the approach to take.
The original poster expresses confusion regarding the role of friction and how to start the problem, indicating a need for clarification on these concepts. There is also mention of the coefficient of friction, which may influence the discussion but is not fully resolved.
cryptcougar
Two blocks connected by a rope of negligible mass are being dragged by a horizontal force Fvec. Suppose Fvec = 70.0 N, m1 = 11.0 kg, m2 = 26.0 kg, and the coefficient of kinetic friction between each block and the surface is 0.100.
Determine the tension T.
Diagram: [ m1 ] ------Tension (T)----- [ m2 ] ------> Force
F = ma
Ok I'm assuming that the Net force pulling the two blocks = 70 N
I really don't know where to start in this problem I've tried finding the Forces of the friction
on the blocks and subtraced them from the net force but I'm just confused.
Welcome to PF.
You got the F = ma part ok.
So what gets accelerated?
How much mass determines what the acceleration is right? Less of course the effects of friction.
So how much mass is getting accelerated by the 70N?
And if it is all accelerating together, then what must the net force be on the last mass being pulled with the tension?
I figured it out!
Turns out you don't even need to really now the coefficient of friction.
All i did was find the acceleration of the blocks and use T=m1a
and found the tension
cryptcougar said:
I figured it out!
The Tension needs to not only accelerate the mass, but it also needs to overcome the friction.
Your tension then is m1*a + m1*g*μ
  • · Replies 17 ·
