How can a body have a velocity east and acceleration west?
A body can have a velocity to the east while experiencing acceleration to the west when it is slowing down in an eastward direction. This occurs because velocity indicates the direction of motion, while acceleration reflects the change in speed. When running east and decelerating, the object maintains eastward velocity but has westward acceleration, resulting in negative acceleration. Understanding that acceleration is the rate of change of speed helps clarify this concept. This scenario exemplifies how acceleration can act in the opposite direction of velocity, leading to a decrease in speed.
IntegrateMe
Can anyone explain a real scenario in which this would be possible?
Also, I've read about velocity and acceleration, but their differences still seem to confuse me. How can I better distinguish between the two?
You are running east and begin to slow down. Your velocity is still to the east because that is the direction you are going. You are accelerating to the west because your eastward velocity is decreasing.
... in other words, in order for an object to change speed, there must be acceleration. If the acceleration was in the same direction as you are running, you would speed up. If the acceleration was at some angle not directly in line with your path of travel, you would veer off course. Lastly, if the acceleration is against you, you will slow down. This is known as negative acceleration (also known as deceleration).
The definition of acceleration is the change of speed per time unit. The common equation for linear acceleration is
a = v - v0 / t
where
a - acceleration
v - final speed
v0 - initial speed
t - time
Hope this helps a bit.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 38 ·
  • · Replies 25 ·
