How can I approximate this transfer function?
To approximate the transfer function, it is suggested that if a pole is close to the imaginary axis, it can be treated as having zero damping. This implies that the system behaves nearly purely oscillatory, allowing for the removal of the damping term (ζ) for simplification. The discussion raises questions about whether this approach is valid or if there are nuances that may be overlooked. The focus remains on understanding the implications of near-imaginary poles in system dynamics. Overall, the approximation method hinges on the assumption of minimal damping effects.
gaus12777
I don`t know how can I approximate this transfer function
into this
In my book, pole is close to imaginary axis, so It can be approximated.
Is that not just an assumption of having zero damping? If the pole is near the imaginary axis, the means the system would very nearly be purely oscillatory with no damping and you could just remove the ##\zeta## term to get an approximate answer. Unless I am missing something here...
Likes Kushwoho44
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
