How can I create a switch pattern without using microcontrollers?
  • Thread starter Thread starter Home Tinkers
    Switch
To create a switch pattern for 8 electromagnets without using microcontrollers, consider researching programmable switches or sequencers that can handle on/off commands. A microcontroller like Arduino offers flexibility but requires programming knowledge, which may not be ideal for a quick solution. Look for devices that can record and playback on/off sequences, similar to a macro program for circuits, which could simplify the process. The desired setup should allow for adjustable time intervals and the ability to hardwire a final pattern. If such a device doesn't exist, there may be a market opportunity for a product that combines programmable power control with ease of use.
Home Tinkers
I need to hook up 8 electromagnets and make them turn on and off to a pre designed pattern. I have no idea how to get something to turn on and off in a programmed sequence. I'm sure there are probably ready made programmable switches that come with software but I don't know.
In any case I need the quickest, simplest way to get 8 things to turn on and off in a pattern of my choosing.
Please let me know what to research, what specific things to learn, or items to look at for purchase to complete my project thank you.
You need to specify whether this is a one shot sequence or whether there are time intervals as well as repetitions to be set . That will determine how simple your setup can be.
I would want to be able to do it at time intervals of my choosing to loop until power is disconnected. I want to be able to change the pattern of each electromagnet firing to a new pattern for testing purposes, but the final product can be hardwired to one looping pattern that fires until power is disconnected and does not change.
most flexible is a micro controller like arduino or pic, but you would have to learn programming.
look up "pic led sequencer", or "arduino led sequencer" to get started down that path. "LED chaser" gets hits too.
With a microcontroller the sky is the limit for flexibility.
yea I saw a YouTube vid on microcontrollers how to solder leads into a breadboard and all that...seems time consuming to say the least even if you know what your doing. Then there is the software aspect of it at least I know c++ and a little java that should help. If that's what it takes there are good tutorials for it I guess. I really don't want to invest the time and money into it if there is a work around. I'm thinking if it comes down to using a microcontroller Ill just redesign my project and learn microcontrollers as a hobby on the side of my hobby I'm working on now because they seem pretty nice for lots of applications so I would want to mildly master them. I just really need to get this project near completion in about 1 month so I don't want to take on something like microcontrollers right now.
is there another way though? Maybe some kind of simple switch box that just records your on off commands and plays them back. Something like a computer key macro program for circuits? I would think some company somewhere would of made a unit that can output a range of voltages to different sources and also be programmed to regulate power and go on/off with some companion software. I imagine a box with 12 power-ports that have a specific voltage range and you can hook up any device you want to those ports (using homemade wiring), and using companion software you can program patterns for power flow through ports and power amounts within the range the device would support. If not there is probably money in that for anyone who could make such a thing. So I guess a cross between a power strip and a microcontroller is what I really could use.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
