How can I design an apparatus to resist a 300 lb load moving at 1 m/s?
  • Thread starter Thread starter omalleyt
The discussion focuses on designing an apparatus capable of resisting a load between 5 and 300 lbs, ensuring it moves downward at a constant velocity of 1 m/s. Participants recommend utilizing motors with high gear ratios to achieve a mechanical advantage, which is essential for maintaining the desired speed despite the load's weight. Hydraulic systems are also suggested as viable alternatives for this application. The emphasis is on creating a reliable mechanism that can handle varying weights while adhering to the specified velocity.
  • Understanding of mechanical advantage in gear systems
  • Familiarity with motor specifications and gear ratios
  • Basic knowledge of hydraulic systems and their applications
  • Principles of load dynamics and motion control
  • Research high gear ratio motors suitable for load applications
  • Explore hydraulic system designs for load management
  • Investigate motion control techniques for maintaining constant velocity
  • Learn about safety mechanisms for load-bearing apparatuses
Engineers, mechanical designers, and hobbyists interested in load management systems and motion control applications will benefit from this discussion.
omalleyt
I need to find or design an apparatus, consisting of a wire and a load hanging from the wire, that can resist the load in such a manner as that no matter what the mass of the load is the load will move downwards at a velocity of 1 m/s. The load will be between 5 and 300 lbs. I am open to using motors, hydraulics, or anything necessary to achieve this result.
You should probably use a motor with a high gear ratio (motor spins fast relative to the load). This will allow it to have good mechanical advantage so that the 300 lb load will not slow it down.
30K
