How can I expand this term ∇∙(φuu)
  • Thread starter Thread starter oxxiissiixxo
    Term
oxxiissiixxo
How can I expand this term ∇∙(φuu) and ∇∙(T×u)
∇∙(φuu) where φ is a scalar and u is a vector
and
∇∙(T×u) where T is a second order tensor and u is a vector.
I found out that the solution for
∇∙(φuu) is φu∙∇u+u[∇∙(φu)]
for this the solution is just seemed like
∇∙(AB) is A∙∇B+B[∇∙(A)]
but I just can't fill in the step correctly in between
and
∇∙(T×u) is -u×(∇∙T)+T
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
