How can i get the velocity of waves ?
  • Thread starter Thread starter Mohamed9005
    Velocity Waves
Mohamed9005
if y =0.03sin(50x-300t) (SI UNITS) , the wavelength of the wave is _______
ω=300=2*∏*linear frequency
therefore frequency = 150/∏ hz
then λ=Velocity/frequency
λ=(∏/150)*velocity
i'm stuck here,i seriously don't know how can i get the velocity of the wave
#close request
problem solved
