How can I open and read input files in Xcode for my C++ command line utility?
  • Context: C/C++
  • Thread starter Thread starter 00PS
    files Input
The discussion focuses on how to open and read input files in a C++ command line utility using Xcode. Users are advised to utilize the ifstream class for file handling and to ensure the correct "present working directory" is set, as this often leads to issues when files cannot be found. Solutions include specifying the full path of the file or moving the file into the appropriate directory. Additionally, using cin.getline is recommended for filenames with spaces, and the inclusion of int argc, char * const argv[] in the main function signature is noted as a potential requirement for proper execution.
  • Understanding of C++ programming and syntax
  • Familiarity with file handling using ifstream
  • Knowledge of command line operations in macOS
  • Basic understanding of Xcode project structure and settings
  • Learn about ifstream and its methods for file input in C++
  • Research how to determine the present working directory in Xcode
  • Explore the use of cin.getline for reading input with spaces
  • Investigate the role of argc and argv in C++ command line applications
C++ developers, students in programming courses, and anyone looking to enhance their command line utility skills in Xcode.
00PS
I am in a C++ class, programming a command line utility, and I can't figure out how to open and read from an input file in xcode. any help?
Technology news on Phys.org
Is this a console app or an OS X (Carbon/Cocoa) app?
If it's a console app you want to use the ifstream classes. Look for something like "ifstream example" on google. (Alternately you can use fopen/fclose and the related C methods.)
Right. It's in the console. Here is what I have:
string filecheck(string& tubein)
ifstream InFile;
cin.clear(); //resets input stream if it is in the fail state mode
count<<"Enter the input file name: ";
cin>>tubein; //stores filename
InFile.open(tubein.c_str()); //priming read for filename validity loop
while(!InFile) //filename validity loop
count<<"\n Error: Filename invalid. Please Try again."<<endl<<endl;
cin>>tubein;
InFile.close(); //closes input stream so it can be used by other functions
return tubein;
The problem is most likely that the "present working directory" when your program runs is not what you think it is. You need to either:
- Specify the full path of the file, i.e. something like /Users/oops/filename.txt
- Move the file you want to open into the "present working directory" of your program. I believe you can find this by looking in the "build" directory which is in the same directory as your xcode file, then looking inside "debug".
No luck. The input stream goes into the "fail-state" mode when it reads it in. Do I need to make any stipulations in the project to add the files in? (The files are .txt files)
Stipulations in the project aren't what you want in this case, not for a console app.
You need to figure out what the present working directory is. Try sticking a system("pwd"); at the top of your main() or something?
You may also want to try printing back the filename you are trying to open. For example the code you've got there will fail if there are spaces in the filename.
/Users/.../build/Debug/P11_in1.txt is the directory. What should I do about the spaces in the directory?
I am going to be typing in the filename quite frequently is there some way I can shorten the process, besides typing in the ENTIRE directory
Learn how to use your shell.
- Warren
- Warren
Thanks for the encouragement :)
I totally forgot about that! either way it's not working...
Why are you trying to compile a console app using Xcode, anyway? If you compile the code using the g++ command at the command line, your program looks for input files in your current working directory which is probably the place where your source code and compiled executable are.
Code:
[Jons-Mac-Pro:~/Documents/c++] jtbell% ls
csv.cpp		csv.dat
[Jons-Mac-Pro:~/Documents/c++] jtbell% cat csv.cpp
// Demonstrates using getline() and a stringstream to read a file
// of comma-separated values.
#include <iostream>
#include <fstream>
#include <sstream>
#include <string>
using namespace std;
int main ()
    ifstream inFile ("csv.dat");
    string line;
    int linenum = 0;
    while (getline (inFile, line))
        linenum++;
        cout << "\nLine #" << linenum << ":" << endl;
        istringstream linestream(line);
        string item;
        int itemnum = 0;
        while (getline (linestream, item, ','))
            itemnum++;
            cout << "Item #" << itemnum << ": " << item << endl;
    return 0;
[Jons-Mac-Pro:~/Documents/c++] jtbell% cat csv.dat
8/29/2008,19.54,19.6,19.28,19.38,11204900,19.38
8/28/2008,19.48,19.76,19.38,19.65,11729500,19.65
[Jons-Mac-Pro:~/Documents/c++] jtbell% g++ csv.cpp -o csv
csv	csv.cpp		csv.dat
[Jons-Mac-Pro:~/Documents/c++] jtbell% ./csv
Line #1:
Item #1: 8/29/2008
Item #2: 19.54
Item #3: 19.6
Item #4: 19.28
Item #5: 19.38
Item #6: 11204900
Item #7: 19.38
Line #2:
Item #1: 8/28/2008
Item #2: 19.48
Item #3: 19.76
Item #4: 19.38
Item #5: 19.65
Item #6: 11729500
Item #7: 19.65
xcode is just calling g++ anyway, there is no harm in using it to compile.
But jtbell is right, it is definitely the case that if you run your console app from the command line rather than via xcode you will not have this uncertainty about pwd.
If there are potentially spaces in the file name, you should use cin.getline instead of cin >>. cin >> will stop listening at the first whitespace character.
ok, I think I fixed the problem. Apparently, you need to put the argument 'int argc, char * const argv[]' in int main. I didn't use this before, and I have noticed that xcode's template always has that as the argument. Anyone know why this works?
I have no idea why this would make a difference for you, if you're not actually using the command-line argument variables argc and argv[] in your program.
11K
