How can I solve a Thevenin problem involving two batteries?
This discussion provides a detailed solution to a Thevenin problem involving two batteries and resistors. The approach includes converting voltage sources into current sources using source conversion, calculating effective resistances in parallel, and then converting back to voltage sources. The final Thevenin voltage is determined to be 1.635 V, with a total resistance of 14.545 ohms, resulting in a current of 0.1124 A. Key techniques such as the current divider rule and the golden rule for Thevenin analysis are emphasized.
  • Understanding of Thevenin's theorem
  • Familiarity with source conversion techniques
  • Knowledge of calculating effective resistance in parallel circuits
  • Proficiency in applying the current divider rule
  • Study Thevenin's theorem in-depth for circuit analysis
  • Learn about source conversion methods in electrical circuits
  • Research effective resistance calculations for parallel resistors
  • Explore the current divider rule and its applications in circuit design
Students and professionals in electrical engineering, particularly those focusing on circuit analysis and Thevenin's theorem applications.
vbs
Hi there, I got this question from an old test. I would say I have limited knowledge of electronics and would ask for guidance into what approach to take with this question.
No attempt yet. I thought of breaking it up, in 2, obviously, and then getting the series resistance total, but what then? then I am back at square 1, with a "broken" circuit. What small detail am I missing?
1) Change the voltage source into a current source using source conversion.
i.e current source with current = 12V / 4ohm= 3 A. - lookin at the left voltage source.
you will get 3A current source with a resistor of 4 ohm connecting parallel to it.
do for the other side(right) too. 8/3=2.67A
2) Since you then have resistors in parallel.
the effective resistance on the left will then be (4*7)/ (4+7)= 2.545 ohm
right will be 2.25 ohm.
3) Convert them back to voltage source.
LEft: 2.545 *3 = 7.635 V
Right : 2.25 * 2.67= 6V
The resultant voltage will be 7.635 - 6 = 1.635 V.
Sum of all the resistance = 10 + 2.545 + 2=14.545 ohm
Hence without using thevenin,
I = 1.635 / 14.545 = 0.1124A
Using thevenin,
After using source conversion,
Golden rule: Make current source disappear; make voltage source a short circuit, meaning: treat it just as a piece of connecting wire.
thevenin voltage = thevenin resistance * short circuit current.
then calculate the current you wanted by current divider rule.
hope this helps
Using thevenin,
hope this helps
