How can you determine the forces in equilibrium without using calculus?
To determine forces in equilibrium without calculus, focus on the concept that the net force acting on each point in a system must equal zero. Analyze the forces acting on each ring at points A, B, and C, considering both tension in the cords and any applied forces. Use free-body diagrams to visualize and sum the forces in each direction, ensuring they balance out. The maximum force that each cord can withstand can be considered in the context of these equilibrium conditions. A systematic approach using algebraic equations can simplify the problem without the need for derivatives.
quantum_enhan
I'm not entirely sure how to go about this question, and what to do with the maximum force that each cord can withstand. I tried setting up an equation, then taking a derivative to solve it for the maximum, but I bet there is an easier way, since the derivative got quite messy... Suggestions?
Nothing moves, so what do you know about the net force acting on each ring at A, B and C?
p.s. By the way, calculus is not needed here.
