How did this Lab experiment work exactly?
The lab experiment involved connecting a microphone to a circuit with an LED, which flickered in response to sound input. This flickering LED was aimed at a solar panel, which was linked to another circuit with a speaker, effectively transmitting sound through light. The setup resembles basic optical transmission systems, similar to TV remotes but using visible light instead of infrared. Participants discussed the feasibility of recreating the experiment at home with common electronic supplies, emphasizing the potential for sound amplification. Overall, the experiment illustrates a simple yet effective method of sound transmission using light.
denjay
In my intro Electromagnetism physics class, one of the labs we did was really fascinating. I didn't have a huge amount of interest in it at the time so I don't remember the details of how it worked but now I really want to know.
From what I remember the set up was like this:
We hooked up a microphone to some circuit with an LED. This LED would flicker depending on what sound was input into the microphone. The LED then was held up to what I remember as a solar panel or something similar. The solar panel was attached to another circuit with a speaker. Essentially it transferred the sound from the microphone to the speaker through the flickering of the LED.
Does anyone have an idea of what this is called? I'm assuming it's related to fiber optics in some way but it was a very simple set up that looked like you could make at home with some electronic supplies. Any details would be greatly appreciated.
You just made a basic optical transmitter (led) and receiver (solar panel) - very much the same as the typical TV remote control - but with visible light instead of IR. I would not have thought that you would get enough energy transfer - through a systems like that to actually be able hear anything on the other end - I' think I might try that one!
lol not many ppl know this but you could use that same LED as a light senser.
What supplies would one need to make this?
Hello Den...
Ha I had to laugh at how poorly I read your original post-sorry. I was thinking you ONLY had the Micro/LED then Solar Panel and Speaker. But the Microphone ->small amplifier -> LEDs
The solar panel (cell) may be able to go right to a speaker. I'll bet all available at something like Radio Shack - depending on the distortion levels you would be OK with.
Ether way - with some type of an amplifier(or 2) involved - I can clearly see how this would work.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
