How did v come out of this derivative?
  • Thread starter Thread starter Dens
    Derivative
The discussion focuses on understanding how the variable "v" emerges in the context of differentiating a function related to flux, expressed as a function of "r," which itself is a function of time. Participants emphasize the importance of applying the chain rule and implicit differentiation correctly to derive the relationship. The chain rule is reiterated, illustrating that the derivative of flux with respect to time involves the derivative of flux with respect to "r" multiplied by the derivative of "r" with respect to time. This process clarifies the appearance of "v" in the final expression. Overall, the conversation highlights the application of calculus principles to solve the problem effectively.
Dens
How did "v" come out of this derivative?
I basically understood how to attack the problem and my answer was very close to the key. The only thing bothering me is that v on the top. I cannot see how that could come up anywhere.
I know that the "r" is r = r(t), so that I am only taking the derivative of $$\ln(1 + w/r)$$. I don't see where the v actually is
The flux is expressed as a function of r. You're taking the derivative with respect to t. So, recall the chain rule of calculus: first take the derivative with respect to r and then multiply by the derivative of r with respect to t.
Nope, implicit differentiation. I had forgotten about that
Here's the chain rule: If y=f and u = g[x] are differentiable functions, then \frac{dy}{dx}=\frac{dy}{du}\cdot\frac{du}{dx}
You have the flux expressed as a function of r: \Phi[r] and r is some function of time: r[t].
So, the chain rule says \frac{d\Phi}{dt} = \frac{d\Phi}{dr}\cdot\frac{dr}{dt}
This get's you the answer and it shows why the speed v appears.
How do you get the answer using implicit differentiation?
No you are right, I forget the $\phi$ on the LHS. I was thinking something like
Something = r as a function of t ==> differentiate both sides wrt t ==> implicitly differentiate RHS
http://www.wolframalpha.com/input/?i=D[ln%281+%2B+w%2Fr%28t%29%29%2Ct]
