How Do Electric Fields Interact at Specific Points on the Y-Axis?
The discussion focuses on calculating the electric field on the y-axis due to two positive point charges located on the x-axis. The participants emphasize the importance of considering the direction of the electric field vectors, specifically how the x-components of the fields from both charges cancel each other out. To accurately determine the total electric field, one must calculate the unit vectors pointing from each charge to the point on the y-axis. The correct approach involves expressing these unit vectors in Cartesian coordinates before summing the electric fields. Understanding these vector components is crucial for arriving at the correct answer.
nemzy
Two 2.06e-6 C point charges are located on the x axis. One is at 1.06 M and the other is at -1.06 M
(a) Determine the electric field on the y-axis at .48 M
This is how i did it:
Etotal=sum of E vectors...
E=ke*q/r^2
r^2=1.06^2+.48^2
q=2.06e-6
E1 = Ke*q/(1.06^2+.48^2)
E2= same thing
E1+E2 = total..
answer is wrong..what am i doing wrong
Both charges are positive. The electric field equation is given by
Kq/r^2 * r-hat, which is a unit vector pointing radially away from the charge.
If you draw a picture of the two e-fields, you'll see that the components don't add exactly (in fact, the x components cancel out), so you need to take that into account.
yeah when i was trying to do this i just realized that too..but i still don't nkow how to find the electric field
You should ask yourself: what is the unit vector, r-hat, that points from the point charge to the coordinate in consideration?
IE, for one point charge, what is the unit vector that points from (1.06, 0) to (0, 0.48)? Knowing this, you can express the unit vector r, in terms of cartesian coordinates, and you should see, that when you add the E-fields together, the x-hat components cancel.
