How do I determine which chemical is in which bottle
  • Thread starter Thread starter h_k331
    Chemical
To identify which chemical is in each unlabelled bottle, one can utilize solubility tests. Copper (II) Sulfate Pentahydrate, which is soluble in water, will dissolve, while Copper (II) Sulfide, known to be insoluble, will remain solid. The blue color of the solution indicates the presence of the copper ion, while the black crystals signify Copper (II) Sulfide. Heating the chemicals could also help, as the hydrated sulfate will release moisture. This approach effectively distinguishes between the two compounds based on their physical and chemical properties.
h_k331
I have two bottles of chemicals. I know that one bottle is Copper (II) Sulfide, and the other is Copper (II) Sulfate Pentahydrate. One bottle contains blue crystals and the other bottle contains black crystals. Problem is, the bottles aren't labeled, so the question is how do I determine which chemical is in which bottle.
My thought is to heat a small amount of each chemical, and the one that releases moisture is the Copper (II) Sulfate Pentahydrate. Only problem is that we are currently studying solubility, not hydrates, so I expected the answer to have something to do with solubility. Any help is appreciated. Thanks.
hk
In reply to my own post, I was reading over the solubility rules again and noticed that compounds containing sulfide are insoluble. I sopose I just need to put a small amount of each in water and see which one remains solid.
hk
Thanks Astronuc.
hk
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
