How do I evaluate this Poisson distribution?
KAISER91
So I have figured out what the values for lambda and x are, but I don't know how to evaluate once I plug the values into the formula.
λ = 20
x = 18
= [ e^-20 x 20^18 ] / 18!
exp -20 x 20^18 is easy to find but how do plug in 18 factorial in the calculator?
Simple do 18.17.16.15.14.13.12.11.10.9.8.7.6.5.4.3.2
I'm not sure what you mean.
The answer to the question is 0.0844
What does 18! mean?
micromass said:
What does 18! mean?
I think it simply means the factorial of 18
It's from the Poisson probability distribution formula, which is;
f (x) = (e^-lambda x lambda^x ) / x!
And I just plugged in the values of x and lambda
I'm not sure how to evaluate this
Well, there is usually a factorial button in your calculator, somewhere.
Try under the MATH menu.
What does the factorial of 18 mean?
It just means 18!=18.17.16.15.14.13.12.11.10.9.8.7.6.5.4.3.2.1
Calculate it like that...
I have tried that several times but keep coming up with the wrong answer.
LOLI think it may be something else I'm doing wrong.e^-20 simply means the exponential of -20 ? right??
Yep, I see the factorial button.
I'm using a CASIO 100 so it's simply shift + x^-1 on the calculator.
Well, your formula should be correct. Are you sure your x and \lambda values are correct?
Yes I'm sure.
Let me take a screenshot of it for you.
Well, I get the same answer as the book, so your calculations must be wrong somewhere.
Yep.
Nevermind, I have found out my problem.
I was using the wrong button on the calculator for exponential.
LOL
