How Do I Find the Angle of Force in This Scenario?
  • Thread starter Thread starter homevolend
    Angle Force
To find the angle of force when pulling an object, the correct formula involves using the net force and acceleration. Initially, the user attempted to solve with incorrect values, leading to confusion about the angle. After correcting the mass and force values, they used the equation F = ma to derive the angle. The final calculation showed that the angle θ is approximately 29 degrees. This method will aid in solving similar problems in the future.
homevolend
Question in angle of force: A women is pulling a rock attached to a rope with 10N of force. If the mass of the rope&rock is 30 kg. And if the rope&rock accelerate at 5 m/s squared without friction. What is the angle to the horizonal ground does the woman pull?
Mass= 30kg
Fnet=10N
A=5m/s^2
What I tried to do was use this forumula: (m)(a)=(Fnet)Cos(theta)-Ff
So then I tried to do the 30*5 which is 150 = 10cos-1 But I could find the angle.
I do not know how to corrently find the angle in these types of questions.
thanks!
150 = 10cos(θ)
15 = cos(θ)
but there is no solution. This is because you need more than 10 N to accelerate 30 kg at 5 m/s². In fact, you need 150 N when pulling straight ahead. Is it possible you have copied a number in the question incorrectly?
Yes sorry I did, it is f40N, m=10kg, a=3.5ms/s/s
I was looking at a different quesion. I just cannot seem to find a way to find the angle. I tried drawing a diagram to no avail.
F=ma
40*cos(Θ) = 10*3.5
cos(Θ) = 35/40
cos(Θ) = 0.875
Now take the inverse cosine of both sides to get
Θ = invCos(0.875)
Θ = 29 degrees
Thanks! Now I will know how to find the Θ for my next questions like this. Thanks again, appreciate it.
Most welcome!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
