How do I make a compensation vector?
  • Thread starter Thread starter yamugushi
    Vector
To create a compensation vector for the airplane project, one must utilize vector addition principles. The plane's direction is N74W, while the wind is coming from N20E, resulting in a resultant vector of 324 mph directed N67W. To find the compensation vector, drawing a vector triangle can help visualize the relationships between the vectors. Understanding how to adjust the plane's heading to counteract the wind is crucial for accurate calculations. This method is essential for ensuring the project meets academic standards.
yamugushi
I'm currently doing an airplane project in pre-calc, it is physics related so I put it here.
The problem is I have a plane, it's going N74W, wind is going N20E, the resultant vector is 324mph, and N67W, how do I compensate?
I remember going over it once in class but I really don't want to screw it up since this project (which is a lot bigger than just this problem) is supposed to be a big part of the grade.
I think I'm just supposed to make a vector go NxW, but I'm not sure how to get it.
Hi yamugushi! :smile:
Relative velocities obey the law of vector addition, so draw a vector triangle :wink:
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
