How do I solve this motion problem using the given equations?
  • Thread starter Thread starter faoltaem
    Motion
To determine the maximum height of a playground slide that allows a child to reach a speed of 15 m/s, the discussion highlights the use of energy conservation principles and kinematic equations. The key equation derived is h = (v^2)/(2g), where g is the acceleration due to gravity. By substituting the values, the calculated height is approximately 11 meters. The participant initially struggled with the provided equations but successfully applied energy concepts to solve the problem. The discussion emphasizes the importance of understanding both kinematic and energy equations in physics problems.
faoltaem
I have a problem from a practice physics exam:
The specifications for design of a playgroud slide say that a child should gain a speed of no more than 15m/s by sliding down the eqipment. How tall can the slide be?
these are the equations that we'll be given in our exam:
v_{x} = v_{0x} + a_{x}t
x = \frac{1}{2} (v_{0x} + v_{x})t
x = v_{0x}t + \frac{1}{2}a_{x}t^{2}
v_{x}^{2} = v_{0x}^{2} + 2a_{x}x
although i can work out the answer to the problem i had to look up a new equation because i couldn't work out how to do it with the equations that we were given, so i was wondering if it was possible to do it with one of them, so if you could tell me which one would work the best or if i should just start memorising some new equations, but here's what i did anyway:
v_{max} = 15m/s where g = -9.81m/s
v_{y}^{2} = -2g\Deltay
therefore \Deltay = \frac{v_{y}^{2}}{-2g} = \frac{15^{2}}{-9.81\times-2}
=11m
Thanks
I would work out the energy
gain in kinetic energy = loss in gravitational potential energy
(1/2)(m)(v^2) = (m)(g)(h)
simplifying you get
v^2 = 2(g)h
h = (121)/(2g)
thanks for that, i didn't even consider energy and those formulae are included too so no memorising
once again thanks a bunch
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
