How do we get the formula for the contact force ?
In summary, the conversation discusses how to find the contact force between two masses using Newton's laws of motion. The teacher explains that there is no special formula for this, but rather it can be derived from the equation f=ma. They also discuss the importance of finding the acceleration of the system before applying Newton's 2nd law. The concept of Newton's 3rd law is also mentioned, which states that the contact force for both blocks will be the same. The conversation also includes a discussion of drawing Free Body Diagrams to better understand the forces acting on each block. The output ends with a question about the direction of the forces on m2 and a final statement of appreciation for the help provided.
Taz.
My teacher said there isn't a special kind of formula, you just derive it from f=ma.
This is the diagram:
I assume you want the contact force between those two masses. Your teacher is right. Just apply Newton's 2nd law.
Hint: First find the acceleration of the system.
Yes. I found the acceleration.
Good. Now apply Newton's 2nd law to M1 alone.
To find the the answer in N ?
So-> F= m1 * acceleration that I found for the whole system ?
Ok, I found the answer. But scientifically, I don't understand how.
My teacher said that the contact force for both blocks is the same. How is that possible ? So if a bee flying at 10 km/h hits a car moving at 30 km/h the forces between both bodies is the same. How is that possible ?
Right.
That's Newton's 3rd law. Whenever two objects interact, they exert equal and opposite forces on each other.
Definitely.
Man I love physics. lol.
Ok but why did we use m1 rather then m2 when we applied Newtons second law on m1 ?
If you're applying Newton's 2nd law to m1, why in the world would you use m2?
Draw two Free Body Diagrams, one for each block
Yes but here is what we did:
We found acceleration for the whole system.
Then the questions asked:
Find the magnitude of the contact force between the two blocks.
Why would you use the mass of m1 and not m2 ?
When applying Newton's 2nd law to m1, use the mass of m1.
You can also apply Newton's 2nd law to m2, in which case you'll use the mass of m2.
You'll get the same answer for the contact force either way. (Analyzing m1 is a bit easier, since only one force acts.)
Here's the problem to make it clearer:
My acceleration is: 1.32 m/s^2
And then I just multiplied 1.32 m/s^2 by 1.39 m/s^2.
If I do 1.32 m/s^2 *3.46 m/s^2 I don't get the same answer...
Right.
That's correct.
The contact force is not the only force acting on m2. To apply Newton's 2nd law to m2, you must use the net force: ƩF = m2*a.
I get it. Thanks.
Can you help me to draw a FBD for this problem ?
Sure. First identify the forces acting on each block. What forces act on m2? On m1?
Not sure but
m1-> force coming from m2 and force going forward.
m2->force from F (6.40N) and force of contact.
What do you mean by 'force going forward'? The only thing in contact with m1 is m2.
Right. They act in different directions, of course.
<-m1
<-m2->
or
<-m1->
<-m2->
Taz. said:
<-m1
<-m2->
or
<-m1->
<-m2->
Only one force acts on m1. In what direction does it act?
Well there is the force of contact... Does this count ?
I GOT IT !
Thanks !
but just a last question-> for m2 is it 6.20 + F = 2.82 *1.18 OR -6.20 + F = 2.82 *1.18
I don't quite understand what you are doing here. You want:
ƩF = m2*a
The two forces are the applied force "F" which acts to the right and the contact force "Fc" which acts to the left. If you choose a sign convention so that the right is positive, then you have:
+F -Fc = m2*a
6.2 - Fc = 3.46*1.32
And so on.
How would the FBD look like for m2 ?
The applied force F acting to the right; the contact force from m1 acting to the left.
But where are the arrow pointing ?
<-m2->
Like this ?
<-m2->
Like this ?
That doesn't specify which arrow goes with which force. I'd draw it like this:
Code:
<---(Fc)---[m2]---(F)--->
ok sounds good. Thanks for your help. Very good teaching skills.
Related to How do we get the formula for the contact force ?
1. How is contact force different from other types of forces?
Contact force is a type of force that occurs when two objects physically touch each other. This is different from other types of forces, such as gravitational or electromagnetic forces, which can act at a distance without physical contact.
2. What factors determine the magnitude of contact force?
The magnitude of contact force is determined by the amount of force applied, the surface area of contact between the objects, and the materials and textures of the surfaces in contact.
3. How is the direction of contact force determined?
The direction of contact force is always perpendicular to the surface of contact between the two objects. This means that the force is pushing or pulling along the surface, rather than at an angle.
4. Can contact force be both attractive and repulsive?
Yes, contact force can be both attractive and repulsive. An example of attractive contact force is when a magnet sticks to a metal surface. An example of repulsive contact force is when two magnets with the same polarity push each other away.
5. How can we measure contact force?
Contact force can be measured using a force sensor or a force meter. These tools can measure the amount of force exerted when two objects touch each other. Another way to measure contact force is by using equations that take into account the factors mentioned in question 2.
