How Do You Calculate Additional Wavelengths in an Emission Spectrum?
The discussion focuses on calculating additional wavelengths in an emission spectrum after determining the energies of the first three excited states of an unknown substance. The calculated energies for the excited states are approximately 4.82 eV, 6.41 eV, and 7.22 eV. To find additional wavelengths, participants suggest using energy differences between these states for transitions, but there is confusion regarding the expected results, particularly for a wavelength of 152 nm. The conclusion indicates that the book's answer may be incorrect, as it contradicts the energy-wavelength relationship, where shorter wavelengths correspond to higher energies.
crimsondarkn
I solved a, but I couldn't figure out b... I've tried different combinations but nothing turned out correctly...
The emission spectrum of an unknown substance contains lines with the wavelengths 172 nm, 194 nm , and 258 nm, all resulting from transitions to the ground state.
a) Calculate the energies of the first three excited states.
b) Calculate the wavelengths of three other lines in the substance's emission spectrum.
E = hc/ wavelength
wavelength 1 = 2.58x10^-7 m
wavelength 2 = 1.94x10^-7 m
wavelength 3 = 1.72x10^-7 m
a) First Energy level : E = ((6.63x10^-34)(3.00x10^8)) / (2.58x10^-7) = 7.71 x10^-19 J
Convert to eV: 7.71x10^-19 J / 1.6x10^-19 J/eV = 4.82 eV
Second Energy level : E=((6.63x10^-34)(3.00x10^8)) / (1.94x10^-7) = 1.025x10^-18 J
Concert to eV: 1.025x10^-18 J / 1.6x10^-19 J/eV = 6.41 eV
Third Energy level: E = ((6.63x10^-34)(3.00x10^8)) / (1.72x10^-7) = 1.1564x10^-18 J
Concert to eV: 1.1564x10^-18 J / 1.6x10^-19 = 7.22 eV
b) lamda = hc/Ef-Ei
I know it has something to do with subtracting with the 3 energy levels from above to figure out the three new lamdas but that didn't turn out properly.
the answers are: 518nm,782m, and 152 nm.
If anyone could point me to the right direction, I'd be greatly appreciated.
You've found the energies of the first three excited states: n = 2, 3, & 4. The wavelengths you were given correspond to transitions to the groundstate: from n=2 to n=1, n=3 to n=1, etc.
But transitions do not always have to be to the ground state; they can be from any higher level to any lower level. Using those 3 excited states, what possible transitions exist?
You have three different energy levels each going to the ground state in the first problem, as correctly solved by you. The second part asks for three wavelengths: the wavelengths of photons emitted when the third excited state goes to the second and first excited states, and when the second excited state goes to the first excite state.
Okay, I've done all the calculations but one doesn't give me the right answer... I'm not sure if its the book's error so if u guys could check please..
Three possible transactions: (7.22-4.82) , (7.22-6.41), (6.41-4.82)
wavelength 1 = hc/Ef-Ei = (6.63x10^-34)(3.00x10^8) / (7.22-4.82)(1.6x10^-19) = 5.17x10^-7 m = 517 nm
wavelength 2 = hc/Ef-Ei = (6.63x10^-34)(3.00x10^8) / (6.41-4.82)(1.6x10^-19) = 7.81x10^-7 m = 781 nm
wavelength 3 = hc/Ef-Ei = (6.63x10^-34)(3.00x10^8) / (7.22-6.41)(1.6x10^-19) = 1.534x10^-6 m = (1534 nm?)
Either the book missed the last digit or my answer is wrong since 152 nm is shown in the book for wavelength 3. and yeah..my other answers are off about 1 but that's pretty close ,since we are dealing with such small numbers after all... Thanks again.
The book must be wrong since its answer (152 nm) is the shortest wavelength and would have a higher energy than any of the other emissions (shorter wavelength = higher energy).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
