How Do You Calculate the Charge on Beads in a Hemispherical Bowl?
The problem involves two identical beads with mass and charge placed in a hemispherical bowl. The beads move to an equilibrium position where they are a distance apart, and the task is to determine the charge on each bead using relevant physics equations.
  • Mixed
  • Participants discuss the forces acting on the beads, including gravitational and electrostatic forces, and their components in different directions. There are attempts to set up equations based on these forces, with some questioning the role of angles in the problem.
Some participants express confusion about the components of forces and their relationships, while others provide clarifications and corrections to earlier statements. There is an ongoing exploration of the equations needed to solve the problem, with no clear consensus yet.
Participants note that the problem is part of a homework assignment and mention the importance of understanding the concepts for an upcoming test. There are references to specific angles and components that may affect the solution.
Hov
"Two identical beads each have a mass m and charge q. When placed in a hemispherical bowl of radius R with frictionless, nonconducting walls, the beads move, and at equilibrium they are a distance R apart. Determine the charge on each bead. (Use k_e for ke, g for the acceleration due to gravity, m, and R as necessary.)"
Here's a picture:
http://img3.imageshack.us/i/p2368.gif
Relevant equations include Coulomb's Law, and other elementary physics equations.
F = Ke * (q1) * (q2) / (distance)2
Where Ke = 8.9 x 109
So what I've gotten so far is this:
Using the left-most ball as a model, there's a force in the negative x direction from the ball on the right. That force is exactly
F = -Ke * (qe)2/R2
Now there's a y component of the normal force from the hemisphere given by:
mgsin(x) = N
So, I also figured that the normal and the gravitational forces should each have an x component and that it should be equal and opposite of the force from the charge on the right:
Ncos(x) = Force from the charge
So here's what I did from there:
Ncos(x) = Ke * (qe)2/R2
Nsin(x) = mg
tan(x) = mg / ( Ke * (qe)2/R2 )
R2 / tan(x)mg = Ke * (qe)2
R2 / tan(x)mg * Ke = (qe)2
And ended up with:
qe = sqrt ( R2 / tan(x)mg * Ke )
Which is incorrect.
One component of weight of the bead balances the normal reaction and other component pulls it down.
One component of force of the bead balances the normal reaction and other component pulls it up along the hemisphere.
Thank you for your reply.
So just to be clear, the charge force has a y component, even in equilibrium? I was under the assumption that it only had an x component.
Yes. It has both the components.
I'm still stuck on this problem. :(
If θ is the angle between electrostatic force and normal, then
F*cosθ = mg*sinθ
F*sinθ + mg*cos = N
This was a homework question on Webassign. I got it wrong.
But I need to know how to do this for my test on Thursday. Some classmates said that there is no reference to theta in the final answer because it's an equilateral triangle.
Can anyone help me further? I'm very lost on this.
Here is another image since the first one was apparently taken down.
http://img5.imageshack.us/img5/9582/p2368.gif
Never mind, got it. I wasn't too far off in my original attempt.
Nsinθ = mg
is the correct equation. It makes perfect sense now. But I still don't understand why this equation:
N = mgcosθ
Doesn't work. Does anyone know why? According to my diagram, the two forces should be equal.
Sorry.In my post #6, the sin and cos are interchanged. It should be
F*sinθ = mg*cosθ. Here θ = 60 degrees. Try it.
I don't think that's correct.
The system of equations should be:
Y component: Nsinθ = mg
X component: Ncosθ = Fe
I understand how to do this problem now, and got the correct answer (finally). My question now is why couldn't the first equation be written as:
N = mgcosθ
Because according to the diagram, wouldn't these two be equal?
Thanks again for your help rl.bhat.
In equilibrium condition your method is correct.
You will get the same result if you use the equations in my post 9#
Here N consist of two components.If you take the angle between the vertical and normal as θ, then
N = mg*cosθ + F*sinθ
  • · Replies 18 ·
  • · Replies 97 ·
