How Do You Calculate the Charge on Spheres with Unequal Charges?
To calculate the charges on two spheres that attract each other with a force of 1.2x10^-9 N and are 4 cm apart, one must use Coulomb's law, Fe = KQq/r^2. Given that one sphere has twice the charge of the other, the relationship can be expressed as Q = 2q. After converting the distance from centimeters to meters, the equation simplifies to finding q, which can then be doubled to determine the second charge. The discussion highlights the importance of proper unit conversion and confirms that solving for one charge provides the necessary information to find both. Understanding these calculations is essential for solving similar physics problems.
LampMan
two charged spheres 4 cm apart attract each other with a force of 1.2x10^-9 . determin the magnitude of the charge on each if one has twice the charge (of the opposite sign) as the other.
Fe = KQq/r^2
well you are only given Fe and r, plus the info that Q is = to (2)q and k = 9.0x10^9 so I am stumped after this step
1.2x10^-9 = (9.0x10^9)(2)qq/16
In your equation everything is a number except for q. Can you solve it for q? Also, you forgot to convert cm to meters.
could it possibly be that I am using the wrong equatiom? and should be using E(force intensity) = kq/r^2 instead of coulombs law??
edit: yes i forgot to convert haha good call..but yea the fact that I am finding two charges throws me off...so would just solving for one q give me the charge I am looking for, then just double it to get the 2nd charge?
Correct. Find q then double it. It is that simple.
aha well I've mised 2 of 2 classes on this unit so i can't believe it was that easy now that i see it ahhh well thanks alot
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
