How Do You Calculate the Maximum Height of a Projectile Using v, Theta, and g?
To calculate the maximum height of a projectile using initial velocity (v), launch angle (theta), and gravitational acceleration (g), the vertical component of the initial velocity is given by v0y = v sin(theta). The time to reach maximum height can be derived from the equation 0 = v0y - gt, where the final vertical velocity is zero. Substituting this time into the kinematic equation for vertical displacement, y = v0y t - 0.5gt^2, leads to the formula for maximum height. The final equation simplifies to dy = (v^2 sin^2(theta)) / (2g). This provides a clear method for determining the maximum height of a projectile.
Jaramia
1. I am trying to derive the equation for maximum height of a trajectory. Must be in terms of v, theta, and g.
2.Vy=vsin(theta) dy=vsin(theta)t+0.5gt^2
3. I know that I must find the point when the vertical velocity is equal to zero and must find one equation for time. Then sub this equation into another.
So I found from the first equation that t=dysin(theta) and then substituted this equation to the second equation listed above. I then got this equation dy=vdsin(theta)+0.5g(dsin(theta))^2.
I don't know what to do from here because of the two displacements. And I don't even know what I am doing is correct as I can't solve.
Can anyone help lead me in the direct equation, it would also be helpful to acctually show me what the max height equation looks like.
You're going to need more than one equation to figure this out, but I'll narrow it down for you. We're given that the final velocity vy is equal to zero, and we're given g, v, and theta. We want to begin by placing the initial velocity in the x-direction and the initial velocity in the y-direction in terms of v and theta. To do so we use the equations:
v_{0x} = v cos \theta
v_{0y} = v sin \theta
From the kinematic equations, we'll want to use:
y = v_{0y} - 0.5(g)t^2
You know how to get v 0y in terms of v and theta, so now we focus on how to get the time t into the given terms. Note again that the final velocity in the y-direction is zero, thus:
0 = v_{0y} -gt
Solve this for t and you're in business.
In the kinematics equation, what happened to the t?
and can you explain what Voy is opposed to Vy?
Oh sorry you're right, that should be:
y = v_{0y}t - 0.5(g)t^2
Also, v0y is the initial velocity in the y-direction, and vy is the final velocity in the y-direction, which should be zero, right?
I forgot to put the "v" in the initial velocity equations the first time around. Just to clarify, they should be:
v_{0x} = v sin \theta
v_{0y} = v cos \theta
Does this make sense?
can you possibly explain how Voy-gt equals zero?
One of the kinematic equations for the y-direction is v_y = v_{0y} -gt. If we know the final velocity in the y-direction to be zero, then we have:
0 = v_{0y} -gt
Does that make sense?
That would be 0=Voy-g*tfinal then
In general 0=Voy-gt is not true, except at tfinal, which is the time when it reaches the peak
ok everything makes sense now.
i substituted the equation and came up to
dy=(v^2cos(theta)^2)/g) - (vcos(theta)/2)
Have i done this right so far? if so, how can i continue?
That would have been right if I had got more than three hours of sleep, I do apologize. It should be sine of theta, not cosine in your equation. You'd use:
v0x = vcos \theta
v0y = v sin \theta
But substitute the sin in for the cos, and you're good to go.
Oops, one last edit. You're missing one term, and a few squares. Your answer should be:
dy=(v^2sin(theta)^2)/g) - (v^2sin(theta)^2/g2)
ok thank!
You're welcome, but also note that the final answer can be simplified :)
ya i got it, thanks again
