How Do You Calculate the Oscillation Frequency of a Compressed Rubber Pad?
  • Thread starter Thread starter Barrowlands
    Spring Units
To calculate the oscillation frequency of a compressed rubber pad, the angular frequency ω can be derived using the formula ω = sqrt(k/m), where k is the spring constant and m is the mass of the object. The spring constant k can be expressed as k = mg/x0, with x0 being the displacement of the pad. Substituting this into the angular frequency formula results in ω = sqrt(g/x0). The units of this equation yield radians per second, confirming that the frequency can be calculated using f = ω/(2π). The discussion clarifies the relationship between angular frequency and frequency while addressing unit consistency in the calculations.
Barrowlands
So, I'm trying to brush up on my undergrad physics, and I'm sure this is a bone-headed question, so please bear with me.
A heavy object, when placed on a rubber pad that is to be used as a shock absorber, compresses the pad by 1cm. If the object is given a vertical tap, it will oscillate. Ignoring the damping, estimate the oscillation frequency. [The book I'm using actually gives the solution]
x(t)=A*sin(sqrt(k/m)t+\phi)
ω=sqrt(k/m)
F=k|l-l0|
We'll call x0 the equilibrium displacement, x0=1cm
k=spring constant of rubber
so
k(l-l0)=k*x0=mg (equilibrium)
gives us
k=(mg)/(x0)
then
ω=sqrt(k/m)
which eventually solves to
ω=sqrt(g/x0)
The book gives an answer of sqrt(980) rad/s. My question is given the units from ω=sqrt(g/x0) (meters, seconds, centimeters), how do they arrive at radians?
X0 is 0.01 m. So the unit of sqrt(g/x0) is 1/s.
ω is the angular frequency, it is measured in radians/second, but radian is dimensionless. ω=2πf (f=frequency).
ehild
Makes sense. I actually just beefed the algebra cancelling my units. Thanks!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
