How do you calculate the speed of a bullet using a ballistic spring system?
To calculate the speed of a bullet using a ballistic spring system, the conservation of momentum and energy principles are applied. The maximum compression of the spring, denoted as d, along with the spring constant k, the mass of the block M, and the mass of the bullet m, are key variables in the equations. The initial speed of the bullet, vB, can be derived from the relationship involving the final velocity of the bullet-block system after the bullet is fired. The correct expression for the bullet's speed is vB = sqrt((k*d^2(m + M))/m^2). This formula incorporates the necessary parameters to accurately determine the bullet's velocity.
1831
You have been asked to design a "ballistic spring system" to measure the speed of bullets. A spring whose spring constant is k is suspended from the ceiling. A block of mass M hangs from the spring. A bullet of mass m is fired vertically upward into the bottom of the block. The spring's maximum compression d is measured.
Find an expression for the bullet's speed.
Express your answer in terms of the variables m, M, k, d, and constant g.
Ki + Ug + Usp = Kf + Ug + Usp
I used conservation of momentum to find the final velocity of the bullet+block
(m+M)vf=mvi + Mvi
so...
vf=(m/m+M)*vB
where vB is the initial speed of the bullet.
Next, I used:
(1/2)mvi^2 + (1/2)kd^2 + Mgd = (1/2)mvf^2 + (1/2)kd^2 + Mgd
0 + (1/2)kd^2 + 0 = (1/2)(m+M)[(m+M)^2*vB^2] + 0 + Mgd
I found the answer to be:
((kd^2 - Mgd)(m+M))/m^2 = Vb
but this was not correct...please help me.
I got it...nevermind
Could someone please explain this, I got the following, but it is not correct
vB = (k*d^2(m + M))/m^2
I figured it out, i was missing the square root. The answer is:
