How Do You Calculate the Voltage Drop Across a 100 Watt Light Bulb?
  • Thread starter Thread starter lespaul5895
To calculate the voltage drop across a 100-watt light bulb, it is essential to understand the relationship between power, voltage, and current. A 100-watt bulb dissipates 100 joules of energy per coulomb of charge, leading to the conclusion that the voltage drop is 100 volts. This is derived from the equation where power (in watts) equals voltage (in volts) multiplied by current (in amperes). Therefore, if the bulb dissipates 100 watts, the current is 1 ampere, confirming that the voltage drop is indeed 100 volts. Understanding these fundamental electrical principles is crucial for solving related problems in electrical engineering.
lespaul5895
Right now I'm a first year electrical engineering student at Purdue University. I have a problem that I have to do for a homework assignment I read the entire chapter and cannot find out how to do this problem. Any help would be appreciated, if this isn't the right place to ask this question just let me know and if not I would appreciate any information on how I could find help.
A 100 watt light bulb dissipates 100 joules of energy per coulomb of charge. Find its voltage drop.
Thanks in advance.
call me dense but I don't see the relationship there, I don't see how those equations relate to the problem given. Most of those deal with current and resistance, please explain. sorry I'm kinda slow when it comes to learning stuff and I want to make sure I fully understand this.
edit: So what you're saying is that 1Watt = J/C? so the equation would read 100w = 100J/1C = 100V?
I was showing that 1 V = 1 J/C and so 100 V = 100 J/C.
Now, 1 W = 1 J/s, and if 100 W dissipates 100 J/C, that implies (100 W)/(100 J/C) = (100 J/s)/(100 J/C) = 1 C/s = 1 A.
So for a 100 W light bulb to dissipate 100 J/C, the voltage drop is 100 V, and the current is 1 A.
See also - http://science.howstuffworks.com/question501.htm
What are amps, watts, volts and ohms?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
