How Do You Construct Excited States in a Two-Boson Harmonic Oscillator?
The discussion revolves around constructing excited states in a two-boson harmonic oscillator within the framework of quantum mechanics. Participants explore the formalism for identifying and expressing the first and second excited states, considering the implications of indistinguishable particles and the appropriate use of raising operators.
  • One participant questions whether the first excited state can be represented as ## \frac{1}{\sqrt{2}} (|1,0\rangle + |0,1\rangle) ## or if pure states need to be considered separately.
  • Another participant asserts that the expression is indeed a pure state, emphasizing the indistinguishability of the bosons and the need for proper tensor product operators.
  • A later post raises a question about the second excited state, suggesting it results in a linear combination of states ## |2,0\rangle, |0,2\rangle, |1,1\rangle ## and whether this constitutes the excited state.
  • Some participants clarify that while the second excited state can be represented as a linear combination, it is not the only possible representation, as there can be orthogonal combinations that are symmetric or antisymmetric.
  • There is a discussion about the nature of degeneracy in energy levels, with one participant expressing confusion about whether a degenerate state must consist of multiple states with different properties.
  • Another participant suggests that two orthogonal degenerate states can be represented as ## \frac{1}{\sqrt{2}} (|0,2\rangle + |2,0\rangle) ## and ## |1,1\rangle ##.
Participants express differing views on the representation of excited states and the nature of degeneracy. While some agree on the forms of the states, there is no consensus on whether specific combinations are the only valid representations.
Participants discuss the implications of indistinguishability and the use of tensor product spaces, but there are unresolved questions regarding the completeness of the representations and the nature of degeneracy.
Students and researchers in quantum mechanics, particularly those interested in the behavior of bosonic systems and the formalism of quantum states.
kuy
hy physics forum, I am doing an advanced qm course, but i still have some doubts about the correct formalism and so on..
so i have this problem of a one-dimensional harm. oscillator including 2 bosons.
the hamiltonian would thus be ## \hat{H}=1/2 (\hat{p_1}^2+\hat{p_2}^2+\omega \hat{x_1}^2+\omega \hat{x_2}^2)##
the ground state would be ## |0,0> ## and i have to build first and second excited states.
so my question is, would the first excited state just be ## 1/\sqrt{2} (|1,0> + |0,1>) ## or do i have to consider the pure states ##|1,0>## and ##|0,1>##too? and how would i write that properly with ladder operators?
thanks for your help
kuy
At first, ## \frac{1}{\sqrt 2} (|1.0\rangle+|0,1\rangle) ## is a pure state too!
And yes, this is the first excited state but each of ##|1,0\rangle## and ##|0,1\rangle## can't be because the particles are indistinguishable so you can't know which one is excited.
Each of the oscillators has its own Hilbert space. But when you write things in terms of ##|1,0\rangle## and ##|0,1\rangle##, it means you're considering the tensor product of the two Hilbert spaces and so your operators should be product operators too. So if you want to raise ## |0,0\rangle##, it means you should use the raising operator associated to the tensor product space which is ## \hat a^\dagger=\hat a_1^\dagger \otimes \hat I_2+\hat I_1 \otimes \hat a_2^\dagger ##(some may write it simply as ## \hat a^\dagger=\hat a_1^\dagger+\hat a_2^\dagger ## but you should be careful each operator acts on which Hilbert space.) , where ##\hat I_1 ## and ## \hat I_2 ## are identity operators in the two Hilbert spaces and ## \hat a_i^\dagger |0\rangle_i=C^{(i)}_+ |1\rangle_i ## and e.g. ## \hat I_1 \otimes \hat a_2^\dagger |0,0\rangle=C_+^{(2)} |0,1\rangle ##.
wow, this answer was far better than i hoped for :D thanks Shyan, that brought some clarity for me into undistinguishable particles
ok i have another question: if i make the second excited state with this tensor product raising operator, i get a linear combination of ## |2,0>##, ## |0,2>## and ## |1,1>##. Is that THE excited state? i thought ## 1/\sqrt{2} (|2,0> + |0,2>)## and ## |1,1>## would be separate states
Yes, that's it. Its symmetric so is proper for two bosons. Also its what the raising operator gives us.
But of course you can have a linear combination of ## |0,2\rangle \ ,|2,0\rangle \ , |1,1\rangle## that is orthogonal to the one you got but that would be an antisymmetric linear combination which is used for fermions. Also this is what you get if you raise an antisymmetric first excited state. Of course there may be other linear combinations but they won't be proper base states because we need either symmetric or antisymmetric wave-functions.
kuy said:
i thought 1/2√(|2,0>+|0,2>) 1/\sqrt{2} (|2,0> + |0,2>) and |1,1> |1,1> would be separate states
Why?
No. The second excited state is doubly degenerate.
There is also a linear combination that is orthogonal and symmetric.
Shyan said:
Why?
if you meusure the energy of one particle in the ##|1,1>## state it would be different to one of the ##|2,0>## state, but the total energy is the same.
i was confused because i thought, if a energy level is degenerate, there have to be several states. so is a degenerate state always a linear combination of states with different properties?
or do i need 2 linear combinations for a doubly degenerate state?
You can use ##\frac{1}{\sqrt{2}} \left( \left| 0, 2 \right\rangle + \left| 2, 0 \right\rangle \right)## and ##\left| 1, 1 \right\rangle## as the two orthogonal degenerate states.
  • · Replies 16 ·
