How Do You Determine the Frequency of a Mass Connected to Four Springs?
The discussion revolves around determining the frequency of a mass connected to four springs arranged in a square configuration. The mass experiences forces from the springs when displaced, leading to a need to analyze both horizontal and vertical components of these forces. The participants explore using geometric relationships and Hooke's law to derive the effective spring constant and the resulting frequency of oscillation. A key conclusion is that the frequency can be expressed as √(3k/m) when the mass is displaced by a small distance d. The conversation emphasizes the importance of calculating forces accurately and using similar triangles for simplification.
Aaron7
The mass is connected to 4 springs, each connected to a corner of a square with sides √2 a.
The springs have spring constants k and natural length a/2.
Show the frequency of the mass when it is displaced by d << a towards one of the corners is √(3k/m)
F=kx
When in equilibrium the springs are length a.
The forces acting in the same direction of motion would be (a/2 - d)k and -(a/2 + d)k since the spring is already stretch by a/2.
I am having trouble finding the vertical forces acting on the mass by the other 2 springs.
The length of the spring would be stretched to √(a^2 + d^2) so the force would be (√(a^2 + d^2) - a/2)k but I need to find the vertical component of this force.
Working backwards I find that the vertical force on each of the springs must be kd/2 so that (a/2 -d)k - (a/2 +d)k - kd/2 - kd/2 => -3dk so I can move on to use ma = -3xk etc to find the answer. I see a link between being stretched twice its length already and having k/2 but I am not sure why.
Many thanks.
Rather than try to find horizontal and vertical components, turn your axes so that one of then runs along the direction of the displacement. You will then be looking for the components of the spring forces along that axis.
You should be able to pick out a triangle similar to (in the geometric sense) the force triangle from which you want to pick out the appropriate component. You will already have the side lengths for this other triangle.
Ok, so with the triangle with sides a and d, I would work out the force in the d direction by saying:
The force in the a direction is k(a/2) so the force in the d direction is k(d/2) because the distances a and d are similar to the forces acting in the a and d directions. This gets the correct answer. Is this valid reasoning?
Well, something along those lines, but not exactly that. I don't think you can get away from calculating the change in force due to the extension of the springs. However, if you can find the force f when the spring is in its new position, then the component of that force along the line of the displacement can be had by similar triangles.
If L is the length of the spring at its new location, then the total extension of the spring is L - a/2.
In the figure, the ratio fd/f = d/L holds.
You should be able to determine f from Hook's law and the amount by which L exceeds a/2, the natural length of the spring.
So I have f=(L- a/2)k
=> fd = dk(L-a/2) / L
=> fd = dk - dka/2L
Can I then say cosθ = a/L and since d<<L then cosθ = 1 - θ2/2
so a/L = 1 therefore fd = dk/2 and then complete it from there?
=> fd = dk - dka/2L
Well that looks okay.
I don't think I'd head off into trig land here. You can find L in terms of a and d, and so fd likewise.
You've got fL as the force along the line of a spring as ##f_L = k\left(\sqrt{a^2 + d^2} - \frac{a}{2}\right)## for one spring. Use similar triangles to find the force fd along the line of displacement. After a bit of simplification you should be able to to see what additional simplification is possible when d << a.
