How do you find the normal component of a function F (Stoke's theorem question)
theneedtoknow
This isn't really regarding any specific question, I am just wondering how do I find the normal component of a vector valued function along a surface S?
Stoke's theorem says the integral over a curve of F (dot) dx is equal to the integral of curlF (dot) n dA over the surface bound by the curve. If I have a function F (you can make one up if it helps explain) to integrate over a surface , how do I find the normal component "n" that I need to use?
Hi theneedtoknow! :smile:
n isn't the normal component, it's the unit vector normal to the surface. :wink:
For most surfaces, that should be fairly easy to find. :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
