How Do You Find the Slope-Intercept Form with Given Intercepts?
  • Thread starter Thread starter rcmango
    Form Slope
To find the slope-intercept form of a line with x-intercept 2 and y-intercept 2/3, the slope is calculated as (2/3 - 0) / (0 - 2), resulting in -1/3. The slope-intercept form is then expressed as y = -1/3x + 2/3. A participant highlights the importance of canceling common factors in fractions before multiplying to simplify calculations. The discussion emphasizes the mathematical principle that allows for early cancellation in fraction multiplication. Understanding these concepts aids in accurately deriving the slope-intercept form.
rcmango
find the slope-intercept form for the line satisfying the following conditions
x intercept 2, y intercept 2/3
Please let me know if I solved this correctly. Thankyou.
0,2/3
(2/3 -0) / (0 - 2)
2/3 / -2/1
2/3 * -1/2
-2/6 == -1/3
slope intercept form
so y = -1/3x + 2/3
That is correct.
thanks.
rcmango said:
2/3 * -1/2
-2/6 == -1/3
Rather than instantly multiplying numerators and denominators together, then cancelling, you should cancel first! The common factor of 2 in the numerator and denominator of 2/3 * -1/2 should be canceled to leave you with 1/3 * -1/1 = -1/3
Okay, thanks for the advice, ill definitely keep that in mind. So denominators, and numerators from opposite equations can cancel early for fractions.
Yep!
It's because we can do things like
\frac{a}{c}\cdot\frac{b}{d}=\frac{ab}{cd}=\frac{ba}{cd}=\frac{b}{c}\cdot\frac{a}{d}
Which is why it works.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
