How do you integrate a force with a scalar function to find the total work done?
To find the total work done by a force represented by the scalar function (x² + 2xy) from point O (0,0) to point P (1,1), one must recognize that the force is not conservative, meaning the work depends on the chosen path. The work can be calculated using a line integral of the force along the specified path. However, the discussion highlights a misunderstanding, as the force should be a vector function rather than a scalar function for proper integration. Consequently, the integration cannot be performed as initially thought. Understanding the nature of the force is crucial for accurately determining the work done.
Alia Al-Hajri
Assalam Alikum
Hi everybody… a work done by a force=( x2+2xy) in a distance from..pt O =(0,0) to pt P=(1,1)
Evaluate the total work?
I know the solution is by integrate the force from (0,0) to (1,1)
But how that will be?
since your force is not conservative, the work will depend on the path you take from (0,0) to (1,0). the work will be the line integral of F over that path.
W = /int _C F ds
where C is the path.
Thanks...but I'm afraid that I did't get your idea!
I mean how do you know that the force is not conservative?
well, really, i did not look carefully enough. the force needs to be a vector function, you have given a scalar function.
So...you said that I can not integrate with a force has scalar function..!
Thanks allot
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
