How do you integrate \(\int \sec^{2n+1} x \, dx\)?
nhrock3
\intop_{-\pi/2}^{+\pi/2}\sqrt{(-6sin2t)^2+\sqrt{6}(cost)^2}dt
how to solve it?
i tried
by parts and it looks very bad and complicated
edit
sorry i copied the wrond integral
now it fine
Did you try a U substitution first?
what substitution?
A "u" substitution. Where you pick a section of your integral and substitute it with "u" and replace your limits of integration. Its not in your book?
ok ill take u=sint
so du=costdt
but i can't have dt inside the root
and i can't take it aside apart
You're going to need to use a trig identity too. Sorry, I am doing this in my head.
what identity?
Look at your first term -12sintcost it should be pretty obvious after that.
yes i know it wwas sin2t before
and i brke it into 2sintcost
what to do?
i did z=sint
and simplified it to
\intop_{-\pi/2}^{+\pi/2}\sqrt{36z^2+6}dz
what now?
1) You also have to also change the limits of integration, I think they are -1 and 1 now.
2) Take out a factor of 36 from the integral
3) This should now be a standard integral. If you need more assistance, I would think of letting z=\sinh w/\sqrt{6} and working from there.
i haven't studied hiporbolic functions
could you write it into normal substitution
Okay, try z=\tan w/\sqrt{6}
Maybe I'm forgetting something, but it's not obvious to me what to do after that.
nhrock3 said:
i did z=sint
what now?
I don't see how you got this from your substitution of z = sin(t). dz = cos(t)dt, and as you pointed out already, you don't have a factor of cos(t) outside the integral.
i did it
i got dz/(cos w) type integral
but i can't substitute dz with a w variable
nhrock3 said:
i did z=sint
what now?
I could be wrong, but in step 3, hunt_mat is taking the integral at the top at face value. I don't believe that this integral follows from the original integral of this thread.
Correct I was.
The integral boils down to integrating
<br /> \int\sqrt{1+x^{2}}dx<br />
though.
ok i will try this thing tommorow
good night :)
how to solve it?
i tried
edit
now it fine
Well, that makes a big difference. As I recall, you originally had this integral.
\int_{-\pi/2}^{+\pi/2}\sqrt{-6sin2t+\sqrt{6}cost}dt
Yes Mark. That editing feature can jump up and bite you.
i got now an integral of dt/(cost)^3
what to do?
I am unsure how to do this integral without using hyperbolic function, I used the following functions:
<br /> \begin{array}{rcl}<br /> \sinh x &amp; = &amp; \frac{e^{x}-e^{-x}}{2} \\<br /> \cosh x &amp; = &amp; \frac{e^{x}+e^{-x}}{2} \\<br /> \cosh^{2}x-\sinh^{2}x &amp; \equiv &amp; 1 \\<br /> \cosh 2x &amp; = &amp; \cosh^{2}x+\sinh^{2}x \\<br /> \sinh 2x &amp; = &amp; 2\sinh x\cosh x<br /> \end{array}<br />
With the above the integral becomes simple. The first two are definitions of cosh and sinh, the rest may be derived from those definitions.
how it become simple?
For the integral I posted:
Use the substitution x=\sinh u and what do you get?
i used x=tan t substitution
and i got a different integral
dt/(cos t)^3
how to solve it
I am not sure you can do it that way anymore, as I said, I have been thinking and the only straightforward way of doing it is hyperbolic functions, I put everything that you need in a previous post.
i want to solve it my way
what to do?
The only thing that I can think of is use:
<br /> t=\tan\left(\frac{x}{2}\right)<br />
I don't think that it will get you anywhere with this method, good luck though.
  • #31
ok but i get the same integral s before
  • #32
Like I said, I can't think of any other way of doing it other than the way I have mentioned. Perhaps your lecturer can.
  • #33
Integrating I_n = \int \sec^{2n+1} x dx:
1. Integrate by parts to get a recurrence relation.
With u=\sec^{2n-1} x , du = (2n-1) \sec^{2n-2} x \cdot \sec x \tan x dx and dv = \sec^2 x dx, v= \tan x we have
I_n = \int \sec^{2n+1} x dx = \sec^{2n-1} x \tan x - \int (2n-1) \sec^{2n-1}\cdot \tan^2 dx
= \sec^{2n-1} x \tan x - (2n-1) \biggl( \int sec^{2n+1}x dx- \int \sec^{2n-1}x dx \biggr)
= \sec^{2n-1} x \tan x -(2n-1)\left( I_n - I_{n-1} \right)
I_n = \frac{\sec^{2n-1} x \tan x +(2n-1)I_{n-1}}{2n}
This eventually reduces the problem down into I_1 = \int \sec x dx = \int \frac{\sec x (\sec x + \tan x)}{\sec x + \tan x} dx = \log |\sec x + \tan x| + C
2. Make a substitution, then integrate a rational function.
I_n = \int \frac{\cos x}{\cos^{2n+2} x}{dx} = \int \frac{ d(\sin x) }{(1-\sin^2 x)^{n+1} } = \int \frac{1}{(1-u^2)^{n+1}} du
Now it is a simple but tedious exercise in partial fractions.
3. Let x= \sin^{-1}\left(\tanh t\right), then
I_n = \int \cosh^{2n} t dt
\cosh^{2n} x= \left( \frac{e^x + e^{-x} }{2} \right)^{2n}
= \frac{1}{2^{2n}}\left( \binom{n}{0} e^{2nx} + \binom{n}{1} e^{2(n-1)x} + \binom{n}{2} e^{2(n-2)x} + \cdots + \binom{n}{n-2} e^{-2(n-2)x} + \binom{n}{n-1} e^{-2(n-1)x} + \binom{n}{n} e^{-2nx} \right)
= \frac{1}{2^{2n-1}} \left( \binom{n}{0} \cosh (2nx) + \binom{n}{1} \cosh (2(n-1)x) + \binom{n}{2} \cosh ( 2(n-2)x ) + \cdots
So integrating term by term:
I_n = \frac{1}{2^{2n}} \left( \binom{n}{0} \frac{\sinh (2nt)}{n} + \binom{n}{1} \frac{\sinh (2(n-1)t) }{n-1} + \binom{n}{2} \frac{ \sinh (2(n-2)t)}{n-2} + \cdots + C
where t= \tanh^{-1} \left(\sin x\right).
