Choosing the negative end of V
s as the zero reference, at time zero the left end of the resistor R will be at 10 V while its right end will be held at -5 V by the initial capacitor charge. That will produce some initial value for the current (what is it?). Eventually steady state will be reached and current will stop flowing (the capacitor's voltage will match that of the source voltage). So the current will start at some initial value at time t = 0 and end at zero after some time. That current will follow the standard exponential decay curve, and you should be in a position to write its equation drawing on the "stock" exponential decay expression (akin to your second Relevant Equation, but for current rather than voltage).
Now, knowing the current w.r.t. time you could write an expression for the charge on the capacitor over time and hence its voltage over time. Or, use that current equation to determine the potential drop across R w.r.t. time, and then use Kirchhoff to find V
c in the circuit. But a simpler idea is to just realize that the capacitor will be experiencing a total change in potential of 10 - (-5) = +15 volts. That is, it will follow an exponential "charging" curve starting at -5 V and ending at +10 V, of a total change of +15 V. You should be able to write an expression for a capacitor charging from 0 to 15 V. Then it's just a matter of "offsetting" that by the initial value of -5 V
