How Does Gingerale's Pressure Change in Descending Pipes?
  • Thread starter Thread starter ashwinanand
    Dynamics Fluids
The discussion revolves around calculating the pressure of gingerale at a lower level in a pipe system using Bernoulli's equation. The initial pressure at the upper level is given as 1.50x10^5 Pa, with the gingerale descending by 8.49 m and changing speed from 4.77 m/s to 2.22 m/s. A key point of confusion is the application of height in the equation; the height at the lower level should be set to zero, meaning the height difference must be accounted for correctly. The correct approach involves recalculating the pressure at the lower level by adjusting the height terms in Bernoulli's equation. Properly applying these concepts will yield the accurate pressure at the lower level.
ashwinanand
Gingerale (ρ=1100 kg/m3) moves through a system of pipes in a beverage factory. Initially, it travels through a pipe with a cross-sectional area of 3.80 cm2 at a speed of 4.77 m/s. Gradually, the gingerale descends by 8.49 m while the pipe's cross-sectional area increases to 8.15 cm2. The speed of the gingerale at the lower level is 2.22m/s. What is the pressure at the lower level if the pressure in the upper level is known to be 1.50x10^5Pa?
delta P = P2-P1
P1+(1/2)*rho*(v^2)+rho*g*y
upper level pressure=1.50x10^5Pa
P1 + 0.5(1100kg/m^3)(4.77m/s^2)+(1100)(9.8m/s^2)(8.49m)=P2 + 0.5(1100)(2.22m/s^2)+(1100)(9.8m/s^2)(8.49m)
P1 + 1.04x10^5=P2 + 9.42x10^4
(deltaP)P2-P1=9.80x10^3Pa
upper level pressure- deltaP
1.50x10^5Pa-9.80x10^3Pa = 1.40x10^5Pa
I am confused of if I had used bernoulli's equation right and if the proper height was used. I can't seem to get the right pressure.
this is part of bernoulli's equation and it's correct.
you applied the same height of "8.49m" on both sides of the equation.
If you do this, it means that "the height of the pipe remains the same throughout. ie. its a horizontal pipe parallel and 8.49m above the ground"
however, The question states that the gingerale decended by 8.49m. (height on both side of the equation shd not be the same then, there should be a height difference of 8.49m)
Therefore, we can take a reference point: the lower level as height 0.00m and upper level as height 8.49m.
therefore, rho*g*y at the right side should be equals 0, because we take reference of height. y=0 at the lower level.
Its given that level at upper level is 1.50x10^5 pa, this means that P1 in the bernoulli's equation is 1.50X10^5 and they are asking you to find p2.
Plug in all the relevant numbers and recalculate.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
