How Does Pipe Width Affect Water Flow and Speed?
  • Thread starter Thread starter Fanny Tan
    Fluids Motion
The discussion focuses on understanding how pipe width affects water flow and speed in a heating system. It begins with a scenario where water flows through pipes of varying widths, prompting questions about flow rates, lengths of pipe segments, travel times, and flow speeds. Participants emphasize the importance of using the conservation of mass formula, S1v1 = S2v2, to analyze flow dynamics, noting that flow rate remains constant despite changes in pipe width. The conversation highlights the confusion some users have regarding the formulas needed to solve the problem, particularly for college-level physics. Ultimately, the discussion aims to clarify these concepts and encourage participants to share their calculations and reasoning.
Fanny Tan
Every second, 1.2 cubic meters of water enters a heating system through a pipe of medium width, A, with a cross sectional area of .2 meters squared. The water then flows into a wide pipe, B, with an area of .6 meters squared, and flows out through a narrow peipe, C, with an area of .1 meters squared.
1) what is the flow rate in each pipe?
2) what is the length of the segment of pipe A that contains 1.2 cubic meters of water? What is the length of segment B? C?
3) How much time is required for water to travel the lengths you found in pipe A? B? C?
4) What is the flow speed of water in each pipe?
5) Does the speed of water increase when it enters a narrow pipe? Does the flow rate increase? Explain.
The idea is to post your work,not just leave the problem to somebody else to do it.
What is the formula that u must use??Actually,there are more,but one of them is really of the domain of fluid dynamics.
Daniel.
Daniel.
If i knew the formula that i must use, i wouldn't be asking for help on this forum. I'm just completely clueless on this one. I have no idea what formula to use or how to start. This is from a college level book and I'm only a soph.
Well there's a volume flow rate you can use Area * velocity (Av)... There's also the mass flow rate but it doesn't seem like you need it in this question...
I have no idea what 'sophomore' means...Let's get back to physics.U'll need the conservation law of mass for one incompressible fluid:
S_{1}v_{1}=S_{2}v_{2}
,where 'S' stands for surface and 'v' for speed.
This formula should get through the fourth question.
For the first use the fact that the fluid is incompressible.The flow should be constant.
Assume the pipes are cylindrical.At point b) you're asked about the length of the pipe,when u're given the volume and the surface.I guess this should not be too difficult.
After finding the 3 lengths,at point c) you must compute the time the water flows through each portion of the pipe.U have computed the legths,u know the speeds,the times are easy to find.
At point 5) u need to analyze the conservation law i stated above.
Daniel.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
