How does Pressure affect molar mass?
  • Thread starter Thread starter jessicaanne
    Mass Pressure
In the discussion regarding the relationship between pressure and molar mass using the ideal gas law, it is clarified that molar mass is not affected by changes in pressure. The equation mm = mRT/PV indicates that while increasing pressure results in a decrease in volume, the product PV remains constant. Therefore, variations in pressure do not lead to changes in molar mass. The initial assumption that higher pressure would decrease molar mass is incorrect.
jessicaanne
Will a higher pressure increase or decrease molar mass when using the ideal gas law, but solving for mm... (mm=mRT/PV)
I was thinking higher pressure would = decrease in molar mass, because of the gas laws and because p=1/v but I am not sure if that's right
thanks!
jessie
Chemistry news on Phys.org
Molar mass is not a function of pressure. PV=const, when you increase the pressure volume goes down and PV in denominator doesn't change.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
