How Does Temperature Affect the Expansion of a Rectangular Plate?
Rblswimmer456
A rectangular plate has an area of 76 cm2.
If the temperature increases by 199 ◦C,
calculate the increase in the area. Use
2 × 10−6 (◦C)−1 as an average coefficient of
linear expansion. Ignore terms of second or-
der.
Answer in units of cm2.
I looked through my physics book and there wasn't really anything about temperature vs area and I looked online but I didn't find much so I thought I could just you use the equation:
delta(L)= (alpha)(initial L)delta(T) and I just replaced L with A..so it read...
delta(A)=(alpha)(initial A)delta(T)...and alpha being the coefficient of linear expansion
delta(A)=(2e-6)(76cm2)(199)
..and this was incorrect...any help would be appreciated to point me in the right direction...thank you!
Welcome to PF!
Hi Rblswimmer456! Welcome to PF! :smile:
(ahve a delta: ∆ and a degree: ° and try using the X2 tag just above the Reply box :wink:)
Rblswimmer456 said:
… Use
2 × 10−6 (◦C)−1 as an average coefficient of linear expansion.
"linear expansion" means that every length is multiplied by 2 10-6 per °C …
so an area is multiplied by … ? :smile:
so since its a "rectangular plate" would 2x10-6 be multiplied by 4 to get the total linear expansion?
oops!
oops! just realized my last post was wrong :redface: …
(not completely awake yet! :zzz:)
should have been …
"linear expansion" means that every length is increased by 2 10-6 per °C …
so every length is multiplied by 1.000002 per °C
(did you mean "linear" ? :confused:)
no, nor the area expansion
if the length was multiplied by 2, then the area would be multiplied by 4
if the length is multiplied by 1.000002, then the area is multiplied by … ? :smile:
