How Does the Biot-Savart Law Apply to Angles in an Infinite Wire Calculation?
The discussion revolves around the application of the Biot-Savart Law to an infinite wire, focusing on the interpretation of angles involved in the calculations. Participants explore the conventions for measuring angles and the implications for the resulting magnetic field calculations.
  • One participant expresses confusion regarding the angles theta1 and theta2 when applying the Biot-Savart Law, noting discrepancies with textbook definitions.
  • Another participant suggests that reversing the angle measurements leads to an extra negative sign, prompting a request for clarification on the angle conventions.
  • Some participants question whether the convention of measuring angles clockwise or counterclockwise can be adjusted based on the situation, particularly in relation to the direction of the magnetic field.
  • It is mentioned that the angle theta should be defined as the angle between the vectors r and ds to avoid confusion, emphasizing that the direction of measurement does not affect the final results if approached correctly.
Participants do not reach a consensus on the correct angle conventions or the implications for the magnetic field calculations. Multiple competing views regarding angle measurement and direction remain unresolved.
Participants highlight the importance of defining angles clearly and the potential for confusion arising from different conventions. There is an acknowledgment that the derivation can yield consistent results regardless of the chosen measurement direction, but the specifics of angle definitions and their implications are still debated.
cosmogrl
In using the Biot-Savart Law for an finite wire, I am having trouble understanding the angles. I have sintheta1-sintheta2, where theta1 is measured from point P to the horizontal wire and from the vertical axis, to the left of point P. Theta 2 is measured to the right of point P.
I am ok until there. However, in going from that result to that for an infinite wire, my textbook (Serway and Jewett, Physics for scientists and engineers) says that as x goes to - infinity, theta 1 is (pi/2) and as x goes to positive infinity, theta 2 is (-pi/2). I seem to have those backwards, as theta1 being -pi/2 and theta2 being +pi/2. However, when I do it my way, I get an extra negative sign which should not be there. I am hoping someone can explain to my why theta is pi/2 to the left of point P and -pi/2 to the right of point P.
Here is the Picture of your Book.
if you want to check you are also Correct if you take θ1, Start from the derivation at the Very beginning taking θ negative. You will get same Result.
I have a confusion. The way the diagram shows as in Diptangshu's answer theta increases in clockwise direction but conventionally anti clockwise direction is taken as positive. Can we change the convention as per our situation?
Here the main Issue is Direction of B. And B is Out of the Page as per r x ds direction...which is considered positive.
So you can use any measurement of θ as long as B is directed out of the page. Here the Reference is Vertical axis... You can take Right or Left as positive... And derive to get Same B.
So, when using the equation as provided, is theta 1 always measured clockwise, but theta 2 is measured counterclockwise?
Well if you take angle between r and ds, the limits will be π/2 to 0 and the Whole answer is multiplied by 2.
Which is the actual approach with no confusion... Because in Law of Biot Savart... dB = [μ0i/4π] [i ds sinθ / r2]... The angle θ is angle between the Vectors r and ds.
So doesn't matter what is your direction... If you start from a direction and Approach any problem properly, you Get same results.
Better to take θ angle between r, ds to avoid Confusion.
The book has taken that for Symmetry.
  • · Replies 0 ·
  • · Replies 57 ·
12K
