How does the compressibility of hydraulic fluid affect force?
  • Context: Graduate
  • Thread starter Thread starter neil800
    Hydraulic Practical
The discussion revolves around the impact of hydraulic fluid compressibility on the force exerted by a piston in a hydraulic system. Participants explore theoretical scenarios involving the use of gases and liquids, the implications of fluid compressibility, and the practical applications in systems like car brakes.
  • One participant questions whether introducing a small volume of hydraulic fluid in front of a piston, while maintaining constant gas pressure, would increase the force exerted by the piston.
  • Another participant asserts that as long as pressure is constant, the ratio of gas to liquid volume does not affect the force produced by the piston.
  • A participant expresses skepticism about the argument, linking it to the necessity of using incompressible fluids in hydraulics and suggesting that replacing an incompressible fluid with a compressible one would alter the force output.
  • It is noted that the incompressibility of hydraulic fluids is crucial, with an example provided about brake systems where boiling fluid can lead to a loss of braking action.
  • One participant states that force is calculated as pressure divided by the area of the piston, indicating that if pressure remains constant, the force is also constant regardless of fluid type.
  • Concerns are raised about the variability of pressure in gas-filled cylinders, which could affect the force on the piston during operation.
  • Participants discuss the practical applications of hydraulics versus pneumatics, highlighting the differences in speed and pressure consistency required for different systems.
Participants express differing views on the role of fluid compressibility in hydraulic systems. While some argue that constant pressure leads to constant force regardless of fluid type, others contend that the compressibility of the fluid significantly affects performance, particularly in applications like braking systems. The discussion remains unresolved with multiple competing views present.
Participants reference specific scenarios and applications, such as car brake systems and train brakes, to illustrate their points. The discussion includes assumptions about fluid behavior under pressure and the implications of using compressible versus incompressible fluids.
neil800
If an inert gas is used to force piston with a Pressure say P (Assume the volume of gas to be sufficiently large). I would like to know the following: (consider piston to be horizontal)
1) If say one puts a small volume of a hydraulic fluid in front of the piston. Keeping the same pressure of gas, will he be able to achieve more force off the piston.
2) Go on increasing the volume of fluid and decrease the volume of gas, but keep the pressure of gas constant. What will happen to the force in this case ?
I feel it is the compressibility which should make a difference. But how should I quantify it?
I understand the derivation of hydraulic, but th concept seems impoosible to imagine. How can the same pressure be transferred to the entire huge area generating a huge force differential?
I would like to thank Physics Forums. Cheers!
Pressure P whether it comes from a gas or a liquid will have the same effect.
As long as P is constant, the ratio of the volume of gas/ volume of liquid has no bearing upon the force the piston can produce.
Thank you for the reply 256bits. I was relating it to the need of an incompressible fluid in hydraulics. If this incompressible fluid is replaced by a compressible one, wouldn't it make a diffrence on the force. So I still am not completely convinced with the
You are correct, the incompressibility makes an enormous difference.
(For example, if the hydraulic fluid in the brake lines of your car boils from incompressible liquid to compressible gas, your brake pedal goes to the floor without any braking action at all - that's why brake fluid is selected for a high boiling point as well as low compressibility, and why race cars have arrangements for cooling the brakes).
force = pressure/ area of the piston for a fluid. If as you say the pressure is constant, the force the piston can provide is also constant, and not dependent upon the type of fluid.
Having said that,
If you are worried about the springy-ness of a gas filled cylinder, then as the piston bobbles back and forth the pressure in the clinder is not constant, and neither is the force on the piston.
In a lot of cases the following is where you would use either, though not a full guide:
Pnematics when you need a quick action of the piston and you need the piston to go from start to finsih quickly.You are not too worried about the pressure just as long as the acceleration of the piston matches what you need.
Hydraulics when you want constant speed of the piston. The pressure of the fluid will reflect the force against the piston if the pump is a positive displacement ( it puts out a Q regardless of the pressure ). Hydraulics have good holding power - close the valve from the pump and the cylinder stays put.
If air is in the brake line you will not get the same pressure to the brake pads. If a car's braking system was set up so that by pumping the brakes one could always increase the pressure in the line rather than increase-release with each stoike the same pressure could finally be supplied to the brake pads.
Train brakes use an air supply, and they seem to work fine on air with a constant pressure from the air brake tank.
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 48 ·
  • · Replies 30 ·
