How Does the Force to Start and Maintain Car Movement on Asphalt Differ?
To start moving a car weighing 1500 N on dry asphalt, a force of 1800 N is required due to the static friction coefficient of 1.2. Once the car is in motion, a lower force of 1440 N is needed to maintain movement, calculated using the kinetic friction coefficient of 0.8. The difference in forces is attributed to the higher resistance of static friction compared to kinetic friction. The calculations clarify that more force is necessary to initiate movement than to sustain it. Understanding these frictional forces is crucial for vehicle dynamics on asphalt.
BarCode
A car of weight 1500 N has its brakes locked. Calculate the force needed to begin to drag he car on dry asphalt. How will the force needd to slide it along the asphalt compare with the force needed to start sliding it? Why? (Static coefficient=1.2, Kinetic coefficient=0.8)
Known: weight (1500 N, the mass in N on earth) , coefficients of static and kinetic friction
Ff = (coefficient of kinetic)(normal force)
Fn = mg
(force needed to start it moving)
Force of friction = 1.2 * 1500 N
= 1800N
(force needed to keep it moving)
= Force of friction * coefficient Kinetic friction
= 1800N * 0.8
= 1440N
Now that I have these numbers, I do not know what to write to answer the questions that are asked.
I don't understand why you did 1800*0.8 for the second part. Should it not be 1500*0.8?
Ffr=uFN
These numbers tell you that you need a greater force to get the car sliding than you need to keep it sliding.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
