jackrabbit
- 11
Point A
Point X 11 pounds
5 inches 5 inches ↑ 5 inches 5 inches
_________________________________________________________________
2 pounds 8 pounds
Assume the horizontal line is a rod that is 20 inches long. The 11 pounds upward force is from a cable tied to the middle of the rod at Point A. There is a 2 pound downward force at left end (10 inches to the left of center), and an 8 pound downward force at 5 inches to the right of center. Point X is five inches to the left of center and is just a fixed point (imagine it is a rod sticking out, and that the horizontal rod runs into when it is lifted).
I am trying to figure out if the horizontal rod will rotate around point X, using the basic formula for force re a lever (i.e., the total force at the fulcrum is equal to force on the lever multiplied by distance to the fulcrum).
I experimented with this and found out that the horizontal rod dipped down on the end with 8 pounds. I was trying to understand the math.
My hypothesis, which was completely wrong, was as follows:
First, I thought of Point A as a fulcrum. Which would mean that the net force at this point was the difference between 8 x 5 and 2 x 10, i.e., a net downward force of 20
Then, turning to Point X, I thought the net force would be the difference between 11 x 5 (upward force) and 20 x 5 (downward force), which would mean a net upward force of 15. This would mean the rod would tilt up on the right side.
So, that was obviously wrong, and probably laughably so to those who actually understand this.
Can you please help me? How does the math here work?
Point X 11 pounds
2 pounds 8 pounds
