- 23,755
- 5,958
Have you had a course in introductory physics that includes forces and free body diagrams?
I mean, that's what your description was, lolChestermiller said:This makes no sense to me either.
BvU said:Force is the time derivative of momentum. Momentum is transported sideways by viscosity. (Did I say something like that before?)
Chestermiller said:Have you had a course in introductory physics that includes forces and free body diagrams?
Please point out where I said anything about momentum.seratia said:I mean, that's what your description was, lol
Chestermiller said:Please point out where I said anything about momentum.
Since you have had a course in freshman physics, I have a focus problem for us to work on. Consider two parallel plates with viscous fluid situated between them. One plate is at z = 0 and the other plate is at z = h. Both plates are stationary. The y direction is "into the paper. " Pressure is varying in the x direction from high on the left to lower on the right. The fluid is moving from left to right (i.e., in the x direction) with a velocity which depends on z, and with velocity v=0 at z = 0 and z = h.seratia said:Yes.
As it applies to this problem, the force pushing the fluid against friction (pushing the fluid from left to right) is getting reduced (I am assuming because of the friction it has incurred to get from the beginning of the journey to the middle of the journey, if for example we look at those two points).
The frictional force per unit wall area is the same at points 1 and 2.seratia said:This is not a free body diagram. But it gets the point across:
As you can see, force is lessened at point 2.
No. The lower plate is not moving.seratia said:Not about momentum. But about the description of the two plates. Here is what you said:
"To get an idea of viscous friction, think extreme cases like very viscous fluids like molasses, pancake syrup, and corn syrup. Imagine that you have the fluid contained between two horizontal parallel plates, and you are trying to slide the top plate to the right at constant speed. You need to exert a force on the upper plate to the right and a force on the lower plate to the left to hold it in place. OK so far?"
This is how I interpreted it:
It seems you are wanting to oppose the fluid moving with the plates - so "holding it in place" as you said ("it" being the fluid) while you move the plates, the upper plate to the right and the lower plate to the left.
seratia said:it applies to this problem, the force pushing the fluid against friction (pushing the fluid from left to right) is getting reduced.
This is close to what I'm saying, except that there should be an arrow on the left for each of the shells.seratia said:To say that momentum is transported sideways is to imply that the force is acting at the center of the fluid, and the radial fluid is carried along by shear stress (thus momentum). When I asked before if the force is acting on the middle, I was told no, it acts against the cross sectional area all at once.
Is this what you mean:
