How far did the ball roll during the first 5 seconds of its motion?
  • Thread starter Thread starter mayeh
    Acceleration
A ball rolls down a hill with uniform acceleration, covering 150 meters during the second 5 seconds of its motion. To find the distance rolled in the first 5 seconds, the kinematic equation S = ut + (1/2)at^2 is used, simplifying to S = (1/2)at^2 since the initial velocity is zero. The distance traveled during the second 5 seconds is calculated as the difference between the total distance in 10 seconds and the distance in 5 seconds. Solving for acceleration reveals that the previously calculated value of 3 m/s² is incorrect. Substituting the correct acceleration into the equation allows for determining the distance rolled in the first 5 seconds.
mayeh
pls. help --> acceleration
a ball starts from rest and rolls down a hill with a uniform acceleration traveling 150m during the second 5.0s of its motion. How far did it roll during the first 5.0s of its motion:confused:
pls. help
what have u tried so far so that we can help u?
i tried to get its acceleration and i got a 3m/s^2, but after that i don't know what to do, I'm not even sure if i got it right.
What you have to see first is that the distance traveled by the rolling ball in the next 5 seconds is nothing but the difference between the distance traveled by the ball in 10 seconds and the distance traveled in 5 seconds.
By the simple kinematic equation, we know that:
S=ut+(1/2)at^2
Since the initial velocity u is 0, the ut component of the equation goes and only (1/2)at^2 is left.So the distance traveled in the next 5 seconds is nothing but:
(1/2)a{(10^2)-(5^2)}=150
Solve for 'a'.(It wouldn't work out to 3m/s^2.)
Now, u know 'a' so substitute it in the equation (1/2)a.5^2 to get the answer!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
