How far will the girl run before catching the ball?
  • Thread starter Thread starter YMMMA
    Ball Girl
The discussion revolves around calculating how far a girl will run before catching a ball, using equations of motion. The initial reasoning incorrectly applied vertical velocity to determine horizontal displacement. It was clarified that both the girl and the ball must have the same horizontal displacement to meet. The correct horizontal displacement for both is calculated as 5 meters, based on the ball's constant horizontal velocity. The final consensus emphasizes the need to consider only horizontal motion for accurate results.
YMMMA
Below
Y=1/2 *gt^2
X=Vt
Vf=Vi+gt
The ball will have the same final velocity as Its initial. So, using the last equation 0=5+gt, where g is 10. Therefore, time to reach the maximum height is half seconds. To reach the same height it started from, kt will take another half a second, Totaltime is 1 second. So, its horizontal displacement is x=5(1)= 5m. Since the same time applies for the motion of the girl, she will have moved a distance of 3m. Is my reasoning correct?
Why is that?
Chandra Prayaga said:
Why is that?
Is it not 0 fotr the final horizontal velocity? Should I consider the motion of the girl?
No. It's constant.
What precisely does the question ask you to find?
gneill said:
No. It's constant.
How far will she run before catching it?
It is constant for the horizontal direction and zero vertically. Sorry, I confused my self. Here, the horizontal distance is the initial velocity times the time. What’s incorrect?
What is the direction of the inotial velocity of the ball?
It’s upward
So why are you using that to calculate the horizontal displacement?
The above statement is incorrect. The ball does not have a horizontal velocity component of 5 m/s. Your answer for the girl's horizzontal displacement is correct. Surely they need to have the same horizontal displacement if she's to catch the ball?
Aha, now I know I messed up. Yes they both must have the same horizontal displacement and I used the vertical velocity instead . Got it, Thank you all
Likes gneill
Good for you!
Likes YMMMA
