How fillers are added to silicon fluids?
  • Thread starter Thread starter amrmohammed
    Fluids Silicon
Silicon products often incorporate fillers like silica and carbon black to enhance their properties. The method of combining these fillers with silicone fluids can vary, with powders typically requiring a process called mulling to ensure even dispersion. Factors such as the polarity of the fillers and their attraction to the silicone affect the mixing process. While some silicone polymers can hold suspensions well, achieving a uniform mixture may require specific shear power, which complicates home mixing. Understanding the mulling process is essential for effective integration of powders into silicone products.
amrmohammed
Some silicon products (like silicon greases) have different types of fillers added to it (like silica and carbon black) to give it certain properties. How these fillers are added/combined/"dissolved" to the silicon fluid?
Liquids are mixed with liquids, powders are often ground in, a process called mulling.
Likes amrmohammed
wouldn't the powder settle down after a period of time if it were just mixed with the silicone? are there some kind of minimum shear power to fully mix the components to one mixture, or can I do it at home like mixing water and salts?
It depends on what kind of silicon polymer you have. Usually they are gels or thick fluids which will hold onto suspensions. If it is a fluid it is a complicated but not too difficult subject. It depends on such things as the polarities of what you are adding and whether they are attracted to the silicon - but on several other factors as well. With paint for example there are modified oils that mix with water, furthermore there are intermediary chemicals (I forget the name) which will bind on to the pigment with one end of the molecule and to the oils with the other. Do look up mulling btw!
Likes amrmohammed
Thank you Puma
I tried searching "mulling" and "silicone mulling" but the results were not related to the topic. Are you sure of the spelling?
Yes its right! You'll have to look up mulling paint I guess to get good info. But anyhow basically all you need to know is that powders have to be really finely ground into the carrying medium to disperse it evenly eg by hand with paint this equates to a flat stone, oil, pigment and another flat stone. Sorry to make a meal of this simple process!
Likes amrmohammed
Hello! I've been brainstorming on how to prevent a lot of ferrofluid droplets that are in the same container. This is for an art idea that I have (I absolutely love it when science and art come together) where I want it to look like a murmuration of starlings. Here's a link of what they look like: How could I make this happen? The only way I can think of to achieve the desired effect is to have varying droplet sizes of ferrofluid suspended in a clear viscous liquid. Im hoping for the...
Hello everyone! I am curious to learn how laboratories handle in-house chip manufacturing using soft lithography for microfluidics research. In the lab where I worked, only the mask for lithography was made by an external company, whereas the mold and chip fabrication were carried out by us. The process of making PDMS chips required around 30 min–1 h of manual work between prepolymer casting, punching/cutting, and plasma bonding. However, the total time required to make them was around 4...
