Is Probability Really Easier Than Calculus?
  • Thread starter Thread starter physicsdreams
    Hard Probability
The discussion centers around the perceived difficulty of probability compared to calculus. While many believe probability is easier, this view is subjective. The conversation highlights that probability has various levels of complexity, ranging from introductory courses to advanced topics involving proofs and measure theory. Upper-level probability courses can be as challenging as real analysis, particularly when they delve into abstract concepts like Hilbert spaces and convergence of distributions. Participants emphasize the importance of understanding foundational concepts in probability, such as atomic events and assumptions, to effectively calculate probabilities. They note that introductory courses often simplify the subject, which may contribute to the perception that probability is easier than calculus. However, advanced probability courses require a solid grasp of calculus and linear algebra, indicating that the difficulty can vary significantly based on the course level and content. Overall, the complexity of probability can match or exceed that of calculus, depending on the depth of study.
physicsdreams
It seems like everyone I know believes that probability is much easier than Calc, but I believe that's a subjective point of view.
I know that Calculus has various levels (i.e. I,II,III), but is it really all that much more difficult than probability?
How many different 'levels' of probability are there, and can't probability be just as hard, if not harder than Calculus?
Thanks
Proof based probability, quite complicated.
Computational probability, still can be pretty damn complicated. If you are taking a probability sequence that is lower division (presumably not calculus based then) then of course it can be made very simple and is often designed for non scientist/engineer/math majors.
The courses at my school at least are:
1) Intro to prob/stat (calc based)
2) Intermediate probability (heavy proofs, lots of calculus/analysis)
3) Probability Theory (measure theory, analysis, etc.)
Probability can indeed get pretty hard. I found upper-level probability courses probably as hard as my real analysis ones. Its only the intro classes (computational, not even calc based sometimes) that are really easy.
Thanks
Hey physicsdreams and welcome to the forums.
The concept of probability is pretty simple, but when you have to apply it or work things out when it's not just given in an equation then it takes practice before you start building up the intuition.
In terms of how hard it can get, I would compare the situation of calculus in your first year with analysis in graduate school. In probability you can end up taking probability and then looking at it in a measure theoretic context just like you do in an analysis course.
Just like with pure mathematics, you can get results that are a lot more abstract. In Hilbert spaces we consider systems that have an infinite-number of dimensions. What if you want the sum of infinitely many probability distributions? How do you deal with convergence?
But it's a good idea to know what probability means intuitively before applying all the analysis, measure theory and so on. This means doing probability problems in the context of normal calculations, conditional probability calculations, simulation, normal models (binomial, poisson, exponential, normal, etc) markovian modelling, and stochastic processes.
In addition it would help if you also did a statistics component to help put a lot of this into a different but very recommended perspective.
The real thing about probability is knowing a) what the atomic events are, b) what the assumptions are and c) what these do to define the probabilistic functions for the process.
If you don't know how to do the above and don't understand how this helps you calculate probabilities then you'll be stuck no matter what level you are at.
Also one final thing is to rely on the mathematics over intuition at least initially. If you try and use your intuition, then you'll probably end up being wrong. Build up your intuition from your experience solving problem, not the other way around.
In terms of the 'levels', different perspectives will focus on different models. Markovian models deal with the fact the only thing that affects the probability of the next event is the event before that. This assumption is used in so many fields that it has become a field in itself which is part of what is known as "Applied Probability". It has its own theoretical results concerning how to find long-term distributions, means and so on.
The basic thing is that you need to understand how each 'kind' of probability is different from another. In mathematics we don't just don't start out by studying the most general way (and we don't end up that way either): rather we look at a model that is useful or widely used and then we make small increments of progress on understanding that particular model or framework.
It's because most basic undergraduate probability and statistics courses are geared to teach the simple parts of probability and leave out the complicated bits.
It depends on what kind of probability class you're talking about. Probability theory/mathematical statistics at my college is taught as an advanced sequence and requires Calc III and Linear Algebra as prereqs. I just took the first course, and I'd say it's less abstract than Linear Algebra but not necessarily easier, if that makes sense. We did some proofs, but it was mainly computational, with a lot of integrals and stuff like that.
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
Hello, I’m an undergraduate student pursuing degrees in both computer science and physics. I was wondering if anyone here has graduated with these degrees and applied to a physics graduate program. I’m curious about how graduate programs evaluated your applications. In addition, if I’m interested in doing research in quantum fields related to materials or computational physics, what kinds of undergraduate research experiences would be most valuable?
