How High Does Block m1 Rise After an Elastic Collision with m2?
  • Thread starter Thread starter sailsinthesun
    Collision Magnets
The discussion focuses on calculating the maximum height that block m1 reaches after an elastic collision with block m2 on a frictionless track. The problem involves two blocks, m1 and m2, with specific masses and a magnetic repulsion preventing them from touching. Key concepts include the conservation of energy and momentum, as both kinetic energy and momentum are conserved during elastic collisions. Participants emphasize the importance of understanding the relationship between potential and kinetic energy in solving the problem. The overall approach suggests starting with conservation laws to simplify the calculations.
sailsinthesun
Two blocks are free to slide along a frictionless wooden track ABC as shown in Figure P9.20. The block of mass m1 = 5.02 kg is released from A. Protruding from its front end is the north pole of a strong magnet, repelling the north pole of an identical magnet embedded in the back end of the block of mass m2 = 9.10 kg, initially at rest. The two blocks never touch. Calculate the maximum height to which m1 rises after the elastic collision.
http://www.webassign.net/pse/p9-26.gif
I don't even know where to start on this problem
Conservation laws ring a bell?
Don't over complicate the problem. There is no friction, so all energy is conserved within the system. Think of the relationship between potential and kinetic energy and how they are converted into each other. Also, since there is an elastic collision, you need to use some momentum equations. Keep in mind that momentum and kinetic energy are both conserved in elastic collisions.
