How Is Electric Flux Calculated Through a Cylindrical Surface?
  • Thread starter Thread starter smagf
    Cylinder Flux
smagf
The z-axis carries a constant electric charge density of λ units of charge per unit length with λ > 0. The resulting electric field is \vec{E} = 5 \lambda \frac{x \vec{i} + y \vec{j}}{x^2 + y^2}<br />.
Compute the flux of \vec{E} outward through the cylinder x^2 + y^2 = R^2, for 0 \leq z \leq h.
d\vec{A} = \vec{n}dA
There are three surfaces to compute flux through and I believe that I have to sum those to get the answer. The three surfaces are the two circles that cap the cylinder and the cylindrical face. The unit normal vectors for these are k, -k and \frac{x \vec{i} + y \vec{j}}{\sqrt{x^2 + y^2}}.
My first question:
So for each surface I have an integral over the surface which is the dot product of E and ndA?
My second question:
Because the vector equation of E doesn't involve k and the normal vector equations for the top and bottom don't include i or j, the product E*ndA is 0dA? So those integrals are 0 and I just have to find the integral with the cylindrical surface normal?
My first question:
Yes.
My second question:
Yes.
You could also use Gauss's theorem (divergence theorem) to integrate over the volume of the cylinder.
welcome to pf!
hi smagf! welcome to pf! :wink:
smagf said:
My first question:
yes :smile:
My second question:
yes :smile:
(btw, in this case it's probably easier to change to cylindrical coordinates before integrating, using of course xi + yj = r :wink:)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
