How is sinusoidal current generated?
Sinusoidal current is generated through the interaction of a rotating polarized magnetic field and a conductor, which creates alternating current (AC) due to the geometry of the system. This process can occur in mechanical systems like hydroelectric generators or alternators, where uniform motion of water or other sources induces AC. Additionally, electronic methods such as Wien Bridge oscillators and waveform generator ICs can also produce sinusoidal waveforms. The generation of direct current (DC) is more complex, typically requiring the conversion of AC through rectification. Overall, the fundamental principle behind sinusoidal current generation lies in the changing magnetic fields and the relative motion between the magnetic flux and the conductor.
Kenny Bala
I'm delving into AC as well as attempting to understand the various wave forms used in electrical engineering, and I am curious how engineers are able to generate current which alternates in a sinusoidal manner. What specific phenomena allows us to achieve this? Is it a special circuit, or does it have to do purely with the electromagnetics of a current generator?
Thanks!
Circular function relative motion between magnetic flux and conductor.
is the usual mechanical way ( power generating station, alternator in a car)
it can also be done purely electronically
say a Wien Bridge oscillator
Dave
HIgh current inverters are problematic. In my industry we used zero to adjustable low frequency stepping resistors to roughly simulate 3-phase 'alternating' current.
Thanks!
You can also use a Waveform Generator IC to make sine, triangle and square waves (as well as other waveforms). That is how basic signal generator equipment works:
http://www.analog.com/en/rfif-components/direct-digital-synthesis-dds/ad9833/products/product.html
Thanks!
Hydroelectric generators (the kind at big power stations run by water, such as at the Hover Dam) automatically generated AC electricity. For that matter, ANY uniformly revolving power source (wind, water, whatever) will cause a generator to produce AC electricity.
It's producing DC electricity that is difficult ... it is normally done they easy way by first generating AC, which is easy, and then using a full wave rectifier and associate circuit to convert it to DC.
The current alternates in a sinusoidal manner because of the natural geometry involved in a rotating polarized magnetic field intersecting a wire. As said previously, creating DC is problematic. Producing currents requires changing magnetic fields. Simple motions result in sinusoidal currents.
